ICF to Tridipanel
Last Post 26 Apr 2019 04:07 PM by minotto Disegno. 2 Replies.
Author Messages Informative
minotto disegnoUser is Offline
25 Apr 2019 02:09 AM
I have an ICF wall that will have an EIFS on the exterior. This wall will connect at a 90 degree angle to a Tridipanel with 1" shotcrete on the exterior. How would i treat the joint between the 2? I assume there must be some need for flashing but i don't have clue what to do. Any advice would be most appreciated. I've attached a detail that better illustrates the situation. The home will be located in S. California, therefore minimal rainfall.
Attachment: ICFtoTridipanel.jpg
newbostonconstUser is Offline
25 Apr 2019 10:38 AM
Is the joint horizontal or vertical? Also not sure what you are trying to accomplish connecting a hurricane design wall to a ICF wall that has been proven to make it through hurricanes.
Are they on the same foundation? Is it a safe room?
One would think the EIFS installer would have experience with transitioning.
newbostonconst Thanks for your response.
The joint is vertical. The Tridipanel is used in order to create a vaulted shell roof that begins as a vertical wall connecting at a right angle to the ICF wall. They are on the same foundation.
I'll check with an installer.
People Online People Online: Visitors Visitors: 276 Members Members: 0 Total Total: 276
