Posted By Alton on 14 May 2019 02:14 PM
I like the idea of using beam pockets formed with EPS. Unless the glulams are treated, I would place a non-permeable membrane within the pocket under the glulam to prevent moisture rotting the glulam.
Pretty much this.
Possibly a fluid-applied flashing.
Look into Prosoco FastFlash and their AirDam products.
The FastFlash will protect the beam from direct contact with the concrete.
The AirDam will act as an air/waterproof gap filler that won't push on the beams the way expanding foam might.
