Posted By smartwall on 27 Oct 2019 04:40 PM
Going to need strapping since the webs are 6" vertical. I use a old time form for the same purpose. It's called Premere Icf. It's a plank and rail system with the rails being horizontal. We've had customers that want metal siding and it gives a attachment point every 12". Don't tell anybody but we've also used TF laid sideways for the same purpose. It saves the extra step of strapping and the window trim is easier. As far as the extra insulation, it comes down to cost. We're doing a project with Premere utilizing reclaimed Iso board that we picked up for cheap. It will be 6.5" of foam with a 6" core. Cost will be about 40% less than a standard form with a greater r-value.
Premere is a new one to me, I was reading up on it. All kinds of advantages such as using reclaim. You have had positive experiences vs say a block stack like Fox ?
