Hi all -- I've never installed electrical outlets before. Question: When you install outlets, do they go inside plastic boxes or do they go in by themselves? The "New Work" plastic boxes I see seem too deep to fit in the 2.5 inches of foam on typical ICFs. How are people installing them?
Even the outlets by themselves seem too deep sometimes. I'm seeing 3.5 inch depths on Home Depot product pages for some Leviton AFCI outlets. That's without any box, just the outlet assembly by itself (though I see under 2 inches on some models – not sure if the 3.5 inchers are accurate).
Example: https://www.homedepot.com/p/Leviton-15-Amp-125-Volt-Duplex-Self-Test-SmartlockPro-Tamper-Resistant-AFCI-GFCI-Dual-Function-Outlet-White-R92-AGTR1-0KW/206804820
Thanks.
