Board&Batten detail ICF Assembly
Last Post 07 Jul 2022 01:53 AM by
sailawayrb
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Icf Builders of Florida LLC
29 Jun 2022 05:57 PM
Does anyone have a detail or recommendation for engineered/ cementious vertical siding with batten strips over ICF substrate? LP Smart Side will not warrant if used on ICF. LP recommends 7/16 osb for attachment. anyone used 1x4 furring strips for attachment ? Thanks, JC.
sailawayrb
01 Jul 2022 08:43 PM
We used HardiBoard panel and battens 16" OC. We used Benjamin Obdyke rain screen between the HardiBoard panel and the ICF EPS exterior insulation. The HardiBoard panel rests on HardiBoard cement trim board fastened into the ICF concrete center core using appropriate length concrete tapcons. SS screws made for cement panel were used to fasten HardiBoard panel to the plastic ICF studs per HardiBoard recommended schedule for ICF. The HardiBoard panel was also fastened to PT wood sill that trusses were fastened. Construction photos may be found on our website.
06 Jul 2022 04:41 PM
Sailawayrb, Thanks for the info. can you provide your website address to see your pictures you mentioned ? thanks again... JC.
sailawayrb
Sure thing and you are most welcome. I should have added that BOTH the cement panel and ICF block companies can provide you their guidance/recommendations for hanging stuff on ICF. Cement board is not a problem just like drywall.
www.borstengineeringconstruction.com
Photos may be found on the About Us tab.
Membership:
croccohvacusa
People Online:
