Be sure to insulate any exposed concrete after placement. If it is plus/minus a few degrees of freezing, dimensional lumber should suffice to trap the heat generated by the curing process. If is gets colder, insulated tarps or rigid insulation may be needed. You do not need to heat/horde the entire wall - the ICF panels will trap the heat inside, but be sure to protect sills of W&D bucks. Between days, plastic, lumber, etc will work to protect the inside of the wall and interlock from snow, freezing rain, etc. Also, you should absolutely keep the concrete covered as long as possible. Concrete does not "dry out" it cures. This is a chemical reaction (hence the heat generated during the curing process). This process will continue until all water has been used up. The longer the water is available, the longer the concrete curing will continue, which will often result in a final strength surpassing the original design strength. Ideal curing is under water, which will continue the cure process for up to 7 years (according to an architect I know). The product manufacturing specs or site engineering will typical list a min time that the concrete must be kept above freezing (typically between 48hrs and 7days). Be sure to keep protection in place to trap the heat within the mix for the necessary amount of time. |
