Truss depth for logix brickledge.
Last Post 09 May 2023 12:57 PM by pusherwr. 4 Replies.
MrCadsUser is Offline
26 Feb 2023 09:59 PM
Hello all you happy people
Looking at using the brick ledge as a floor connection. Trusses would be top chord bearing. Does anyone know the exact depth for the trusses to cover the tapered part?
I know the form is 16' high + 1"1/2 for the green treated board. Would 18" be enough?
Thank you!
smartwallUser is Offline
28 Feb 2023 12:06 AM
I wouldn't do it. Your creating a lot of extra work for yourself. Use a joist hanger like Burmons.
ICFBdrUser is Offline
16 Mar 2023 05:44 PM
Agreed. Cast in hangers (several options available) offer more versatility in floor elevation placement and most allow for some adjustment when installing joists (ie, hangers can be +/-1" from correct placement in many cases and still allow for accurate floor placement). These hangers may also offer a higher strength rating than a brick ledge form with a more attractive price point and no corbelled ICF section to interfere with bracing installation.
04 Apr 2023 03:23 AM
Use the Burmons for ledgers, with a mid bearing truss so the bottom cord is flush with the ledger. A brick ledge adds work and expense, unnecessarily.
pusherwrUser is Offline
<a href="https://www.camisetasstore.com/">comprar camisetas de futbol baratas</a>
People Online People Online: Visitors Visitors: 223 Members Members: 0 Total Total: 223
