cement fiber board or osb
Last Post 21 Dec 2006 08:53 PM by azlineman. 4 Replies.
azlinemanUser is Offline
20 Dec 2006 09:11 PM
I'm going to be building a new home in spring 07 and plan to build with sips. I have heard about cement fiber board and wonder what the advantages are of it, vs osb. There is a manufacturer of the cfb about 25 minutes from my building site, which of course would cut down on delivery costs, but i'm just not quite sure if its the way to go. Any help would be greatly appreciated.
20 Dec 2006 11:18 PM
Posted By azlineman on 12/20/2006 9:11 PM
Where are you building? Storm area? Termites? Grizzly Bears?
mmacgowaUser is Offline
21 Dec 2006 01:34 PM
25 miles is going to play a huge part in your decision unless there is an OSB plant within 20 miles. The biggest issues are what you plan to do with your finish and how much you are charged for the components and the engineering. Then add shipping and see which way you want to go. I have two SIP suppliers within 2-4 hours and they charge almost $1/ft difference in raw panel cost. Luckily for me the less expensive SIPs are closer.
21 Dec 2006 06:28 PM
depending on what part of the country you are building you should consider steel sips
i'm building in northern az. i haven't quite decided on exterior finish, siding or stucco. i will have some stone work.
People Online People Online: Visitors Visitors: 185 Members Members: 0 Total Total: 185
