air leakage through SIP/timber-frame screws
Last Post 28 Dec 2006 01:22 PM by mmacgowa. 2 Replies.
edklineUser is Offline
27 Dec 2006 03:58 PM
I built a timber-frame in 2005 and attached a SIP roof and walls with long screws that extend all of the way through the panels and into the timbers.   Each screw has a large washer to keep the screw head from burying into the exterior OSB.  I assume this is the common way to attach SIPs to timber-frames (?).  A light snow is melting off of my roof and I can see a circle where each washer is, where the snow melted first.  I took a scrap of SIPs and pushed a screw through the foam, as the install crew did after penetrating the OSB.  The screw shank is not sealed by the SIP core because the screw threads create a hole that is larger than the shank.  I suspect that interior air is leaking through each screw hole and I am concerned that the exterior OSB will rot.  Does anyone have experience or advice on this?
smartwallUser is Offline
28 Dec 2006 07:17 AM
What you are seeing is conduction of the heat from the inside to the outside by a material that conducts heat at a very high rate,that is why frying pans are made mostly of metal.
Smartwall
mmacgowaUser is Offline
Imagine what your problem would be if the same effect could be seen at each joist? Screws have been around as long as SIPs so I wouldn't be concerned.
People Online People Online: Visitors Visitors: 241 Members Members: 0 Total Total: 241
