Mastic vs. foam & VOCs
Last Post 09 Jan 2007 03:00 AM by tah. 2 Replies.
tahUser is Offline
02 Jan 2007 08:50 PM
Two questions:
1. Some SIP munfucturers use mastic and some use foam. Does any have experence with both and have an educated opinion? I'm guessing the mastic, because it is non-hardening may perform better long term, though foam seals larger cracks. Has anyone done blower door tests on house having both?
2. I notice the Preimer mastic was in a base of naptha! Not exactly low VOC. Anyone have a low VOC option that works well?
panelwrightUser is Offline
05 Jan 2007 08:52 AM
Each has its place. For a tight fit around bottom plates, panel mastic works well when properly applied (no gaps in the applied bead)
The foaming option works better where joints are wider. for instance a roof panel joint that is open up to a 1/2" can easily be completly sealed by injecting an expanding foam.
Beware of the limitations of both single component and two-component foams. Each has its pros and cons.
I teach the combination of using both mastics and expanding foam to properly seal a panel structure. In addition, we use rolled sill seal, adhesive backed foam seal and a variety a SIP tapes. The proper method is a fuction of the type of joint and what type of climate you're building in.
As for panel mastic and VOC's, the two main manufacturers that make the stuff are OSI and Sovereign Chemical and they both contain VOCs. Some panel providers will spec compatable caulks and a few of those are either low or no VOCs.
tahUser is Offline
Any product names you know of?
Its quite troubling in very tight SIP homes we are Spec'ing high VOC mastics.
People Online People Online: Visitors Visitors: 149 Members Members: 0 Total Total: 149
