Posted By gregj on 01/08/2007 3:41 PM
I'm interested in using SIP walls over an ICF foundation. For the garage the SIP would have to sit on the ICF stemwall. I understand I need to put a larger sill plate down first to carry the load from the SIP (the ICF foam can't bear any load).
My question is how much can that larger 2x sill plate "cantilever" out over the 2" of ICF foam?
I don't even know if they make such an animal, but a PT LVL would be perfect. Here is what an engineer specified on a recent project:
The SIPS used were 6.5" wall panels. But this thing was a mess due to an unlevel ICF wall. And, you would have a better structural solution by having the anchor bolts penetrate through both the sill plate and the SIP bottom plate.
