Posted By mmacgowa on 01/20/2007 8:02 AM
Walls can be adjusted at the spline to stop a stair stepping effect from a sill that is not level. Walls are normally put together as tightly as possible but some factories suggest a gap fro shrinking/swelling effects. But if you are not perpendicular to the foundation, you will start stairstepping. It isn't a big deal if you end up long or short on a run. You add material to the end plate or trim the end to fix wall issues. The issue as I was trying to state before is that everything transfers to the roof, where all of your issues become realized!
Mac is right about the "transference". I found out the bad way with my SIP build. I was pretty level at the sill, however, a header (16') long bumped up one side by about 1/4". I did some "shaving" and called it "close enough". The second floor on that side was now about 3/4". After trying to "shave" some more, I went with close enough again. By the time I put the trusses up (hip roof), I had almost 1.5" of height difference. Fortunately for me, my metal roof guy did a great job "making it work". I am obviously NOT a carpenter and learned a valuable lesson. If I had a do over, I would have taken the time to make sure it was level (or with a 1/16" anyway).
