sip/timberframe wiring help
Last Post 21 Jan 2007 04:21 PM by mmacgowa. 1 Replies.
bikingjwUser is Offline
21 Jan 2007 01:32 PM
I am planning on putting SIP panels over a timber frame structure.  I am wondering if anyone has any information or where I could find information on wiring between the timber frame and the SIP?  Example, What would be the best way to wire a hanging lamp or fan through the timber frame and into the SIP?  If the wire is run down a groove routed in a purlin followed by T&G  to a SIP wall, how do i keep the installers from running a screw into the wiring during panel installation?
I am building in the Asheville NC area.
John
828-242-5959
mmacgowaUser is Offline
Your panels should have chases as well. They would avoid the distance problem you speak of. You can also run wiring along a spline. You could use sheet metal to block nails in your purlin chases, but it would be less expensive and take less time to snap lines indicating where not to nail.
People Online People Online: Visitors Visitors: 178 Members Members: 0 Total Total: 178
