Equipment EPS
Last Post 15 Jul 2011 02:45 AM by zhongjieps. 14 Replies.
ivtbizUser is Offline
26 Feb 2007 10:54 PM
Our company would like to buy EPS Equipment.  We need information where we can buy it. We are in Ontario, Canada. Thanks.
Cattail BillUser is Offline
28 Feb 2007 08:05 AM
What on earth for? First off plan on spending at least 2mil for equipment then plan on paying some very high wages to some one who has the expereince to run it if you can even find some one willing to leave the security of the company they now work for. There is not much turn over in this field. then plan on spending more to find product and unless your volume is substantial you will not be able to mold for less than an existing company in this buisness. Sorry do not mean to be condasending but I have researched this and it just does not pencil out.
Dick MillsUser is Offline
04 Mar 2007 11:37 PM
Bill, I have done some research into EPS processing as well, and in many cases I do agree with you.  In fact, to build a state of the art EPS facility currently does cost about $2 mil USD, but what you get for that is a very mechanized plant that can produce millions of cubic feet of Expanded Polystyrene per month.  And when you look at it as a capital investment, it really isn't that extreme - amortized over 30 years it works out to less than $200 per day.  For a 3 shift, 24/7 plant, that is rather inconsequential.
It also buys you systems that are much more efficient in terms of energy usage and quality control.  This is mainly due to vacuum assisted molding techniques and an array of hi-tech sensors that provide feedback to the computer controlled automation.  All of this provides some degree of advantage over other fabricators that are still using much more manual processes.  And, historically, it has been difficult to locate qualified personnel to operate older less automated machinery, that is much less true with a new $2 mil facility.
That said, you do bring up some other issues.  Like locating unexpanded EPS beads.  It is possible to find them, but the price is very directly tied to the cost of oil.  But it is highly unlikely that existing fabricators have any real advantage (with the possible exception of volume discounts and established releationships with suppliers).  But any agreement to purchase a commodity that is so directly dependent on oil prices necessarily has cost adjustments that are tied to the feedstock price.  I have studied EPS fabrication a bit myself, and have been able to locate unexpanded beads for single pound retail quantities at about $3.5/pound (it used to be $2.50/# 6 to 8 months ago).
Comparing that with EPS board that you can buy at Lowes or HomeDepot that is 2" x 4' x 8' and 1# density for $21.5+ per board, you arrive at a retail price on the order of $4.00/#.   Both of those are both retail prices, and very small quantity prices as well, so they are pretty comparable.  That price is also pretty close to prices available from on-line suppliers as well.  So, locating a wholesale supplier (and getting prices closer to 40% to 50% of retail) shouldn't be difficult.  And to them, every customer is just another demand for their product.
All this being said, the only real advantage that any EPS molder can offer is being local to the demand.  Unexpanded EPS beads can be shipped very easily.  When you expand them to 40 times the unexpanded size, the shipping costs can become enormous - not because of weight, but volume.  So, the real question to be asking one's self is:  what is the local demand for formed EPS?  And, how much local supply is available?  The answers to those questions could propel one into a profitable venture . . . or not.
But, now, getting to my real point. . . I assume that most here are interested in EPS for SIPs fabrication.  While EPS may be less expensive than PU (polyurethane foam), why would anyone want to use EPS when PU is a better alternative.  Consider this, 2 part unexpanded PU resin can be purchased for a retail price of about $5/expanded cubic foot (2# density) vs. $3.5 to $4.0/cubic foot for EPS (1# density) either expanded or unexpanded.  So, PU sounds on the surface to be more expensive, although more dense.
But, with EPS, after it is expanded, it then has to be glued to the skins (OSB or fiber cement board, or plywood, or whatever) of the SIP.
The glues necessary to do are not an inconsequential expense either.  Take a cheap (and I mean cheap) polyester based glue with a coverage of around 2mil to 3mil.  Current retail prices in drum quantities of that glue amount to $10 per 4x8 eps panel.  That plus the fact that the expanded EPS foam has to be warehoused, and then handled by machinery to cut it, and then apply the glue, and position it in the panel and then press the panel until the glue cures all adds up to the price of EPS being much closer to PU.  That is due to the fact that PU is mixed and injected into a SIP in one operation, and expands within the panel, and is its own 'glue'.
So, the cost difference dissapears when you factor in the handling and glueing expenses.  Then, I read on Thermasave's website that PU foam emits cyanide gas when it burns.  Any of you who haven't encountered Hoot Haddock, should check out his website (I think it is www.thermasave.com).  His name is quite appropriate, because he is quite a "hoot".  But, that statement of his is highly misleading, and alarmist (which does cast a bit of a shadow on Hoot's reputation).  PU foam does burn (just like EPS does) and can produce trace amounts of hydrogen-cyanide gas when it burns.  But the amount produced might be enough to give you a headache, but not enough to do any real damage - it if did, then the fire would certainly get you first.
When you factor in that PU and EPS basically cost the same to place into SIP sandwiches, then the next consideration is that PU is much more efficient thermal insulation than EPS . . . by a factor of about 2:1.  That should make it easier to sell PU than EPS.  The one last advantage to PU over EPS that I will mention here is that PU panel manufacturers like Murus (www.murus.com) have discovered that by using PU foam injected between the skins of the panel don't require splines to interconnect adjacent panels.
I presume that they do nail down to a continuous sill plate, and at the top to continuous top plates, but adjacent panels can be connected by using camlocks that are simply embedded into the foam.  The adhesion of the PU foam to the skins and to the "wings" and bodies of the camlocks is strong enough that no other splines are required.  They even claim that the camlock connection is stronger than nailed (and foamed / glued) in splines.
So. . . before anyone decides to invest money in a plant to manufacture more EPS blocks, they should at least consider PU in a foamed-in-place processes instead.
Dick
05 Mar 2007 12:57 PM
Dick I can see that you have done almost all of the research that I have, and you are absolutley correct in everything that you have stated. My research was more directly related to one direction knowing that I would have to expand my product baes to make it pay and to be consistant with my employee base.
I have been in the metal fabrication and machining buisness for 30+ years so I do understand the need to have multiple product lines or a broad based customer group.
I was just curious more than anything of the rational in this regard as it may help me to rethink the issue from a different perspective, thank you for your response it has been very informative.
The equipment that I was considering was the kurtz products they where very informative with all of the info that I requested not only from equipment but materials and contacts. They are located in Plymouth, Wisconsin.
NWPUser is Offline
19 Mar 2007 09:44 PM
Would like to talk to you about you research and the people you spoke with.
Ralph Lord
New World Panels, LLC
603-209-4857
19 Mar 2007 11:19 PM
Hi Ralph,
Are you more interested in EPS or PU?
Dick Mills
NWPUser is Offline
20 Mar 2007 02:04 PM
Hello Dick,
jsut in the eps for now.
thanks
Ralph
20 Mar 2007 03:48 PM
Ralph,
If I were you, I would speak with the guys at EPS Machinery.com.
http://www.eps-machinery.com/eps/typicalepsplants/index.html
This is where I got most of my information about equipment.
Dick Mills
sayeevarmaUser is Offline
09 May 2007 10:21 AM
We are manufacturers of EPS SIP ( Sandwich panels) in India.
We can take up cold storage construction on turnkey basis.
We also can take up cleanroom walk-on false ceiling and cleanroom partttions with EPS sandwich panels.
Sayee Varma
Manager
Beardsell limited
47,Gream road
Chennai - 600006
India
wrayjohnsonUser is Offline
07 Jan 2011 01:18 PM
Apparently Hoot and thermasave.us are correct - rigid PU foam does indeed emit cyanide when it burns. See this scientific paper on the National Institutes of health website entitled "Cyanide toxicity from the thermal degradation of rigid polyurethane foam" which shows that it had an adverse effect on lab rats. http://www.ncbi.nlm.nih.gov/pubmed/517435. I found other scientific papers supporting the same. So I am wondering why you would impugn an individual and his business' reputation before you did your homework on the subject?
TorbenUser is Offline
07 Jan 2011 02:41 PM
The experiment your link refers to involves feeding rats thermally degraded rigid polyurethane foam byproducts through "intratracheal intubation" (a feeding tube down the throat). I think this would have negative results with virtually any building product. I don't think this is indicative of any problem using polyurethane foam in SIPs.
CoppersilveradoUser is Offline
22 Jun 2011 12:02 PM
We are also an EPS/EPE and EPP equipment supplier, both for molding and recycling. Please give us a call if you are still interested in machinery, and have a look at our website too. www.foamequipment.com. We have been around and in the industry for a long time. Give us a call. 314-427-4395. Thank you.
22 Jun 2011 03:25 PM
Posted By Torben on 07 Jan 2011 02:41 PM
...as long as you're not jamming them down people's throats, eh?
The biggest toxicity issue with any of the standard foam insulations in current use is the toxicity of the smoke during a fire, which is the basis of the requirement for ignition barriers.  Outgassing during non-fire-emergencies isn't anything like the urea-formaldehydes of '70s vintage foams.  Odds are the OSB facers on PU or EPS SIPs have higher toxic potential than the stuff in the core, and even that is much reduced since 25-30 years ago.  Foamy pads under carpets and paint/adhesive VOCs are bigger problems than anything you'd get out of a SIP these days, yet still well managed by modest amounts of ventilation.
This is all small-potatoes compared to lead paint or asbestos flaking off the boiler & associated plumbing- it's amazing our parents lived long enough to reproduce!
Nothing is perfect- I try not to let the perfect become the enemy of the good. YMMV.
22 Jun 2011 06:02 PM
If you don't smoke and have a modern home, your risk of being harmed by smoke from burning foam but living through the fire is pretty low. On the other hand, I would be more concerned about VOCs and drinking water quality than most people are.
zhongjiepsUser is Offline
please take a look at our website http://www.eps-machine.info and http://www.epsmachinery.asia.we are eps machine manufacturer in china.
People Online People Online: Visitors Visitors: 290 Members Members: 0 Total Total: 290
