Structural Insulated Panels (SIPs)
fire and drywall
Last Post 16 May 2007 01:30 PM by
wheath
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
kavade
12 May 2007 10:41 AM
I'd appreciate it if you folks could tell me about any alternatives you know of for covering inside walls, I mean besides drywall. What else is possible and will satisfy the fire dept? Or is drywall the obvious cost efficient solution? I may well be doing this by myself, and dealing with the ceiling is...clearly a problem.
Kavade
mmacgowa
13 May 2007 07:41 AM
Conseco has a fire paint, but I don't think it has had all the tests. Tests are expensive and each SIP manufacturer has to test the panels with the alternative. And since SIPs are already more expensive then sticks...
Ron Davis
14 May 2007 03:17 PM
Kavade, we are able to manufacture a two hour fire wall up to 30'. If you are interested,
www.ics-sips-fl.com
or feel free to contact me.
Ron Davis
352-483-7477
gregj
14 May 2007 03:23 PM
I don't know of any alternatives but having drywall hung and finished is actually very inexpensive. Check around for subcontractors. If you have to do it yourself find a good drywall lift to rent or buy - You can sell it when you're done. But if you figure the time it will take you, the sore neck from all that overhead work, and the cost to get a lift and other tools you just might decide that hiring a sub is the way to go. You can be working on something outside or in the basement while they rock and get your place done that much faster.
kavade
14 May 2007 09:33 PM
Thanks for the input, folks. I guess I was vaguely thinking along the lines of tumescent paint ( I'll check out the company mentioned above), and I may ask the county if they would okay that, but it seems unlikely.
Thanks again. Kavade
wheath
Check out No Burn, they have several code listings.
Membership:
croccohvacusa
People Online:
