Is anyone useing thermasteel panels, for housing
Last Post 19 Sep 2013 10:29 PM by Cicca. 75 Replies.
Page 1 of 41234 > >>
worldwizeUser is Offline
09 Jun 2007 03:09 AM
hi i was wondering if anyone useing ThermaSteel Panels in any of the work there doing in building a house,if so im real interested in useing it myself for my home .
just let me know how u like it and if there is any tips you can give me on useing it ,and were i can find it.
tommymacUser is Offline
16 Jun 2007 10:33 PM
I love Thermasteel.  this is their website
I recently received my third quote from Thermasteel in Roanoke VA.   I have been moving very slowly on our project, completely changing designs three times.  Mike Meyers, the sales rep, has always been helpful via email.  I grew tired of the expense of an architect and his attitude toward SIPS so I purchased the Chief Architect product, transferred my plans in (three months from novice to pretty darn good) and now I email .pdf files of my plans/changes to Kinkos in Blacksburg VA (home of VA tech GO HOIKES!!).  Kinkos will print 3'x4' to scale drawings (7 pages) for $35 and Mike picks them up and adjusts my quote.
My quote for 4032 sq ft of 5.5" wall panel, with openings, including screws, base track, corner metal, but not including shipping and taxes is $29,149.38 or roughly $7.23/sq ft of SIP.  Is that a good price?
I did receive another quote from a distributor that was 50% higher but included Trade Ready floor joists, something else i like, ttp://www.dietrichindustries.com/traderea.htm  so it is not really an apples to apples comparison.
My only dissapointment, and unresolved problem, is the plan calls for a hip roof with living space in what would be the attic. Thermasteel says they cannot quote the roof since it is a hip roof.  Anyone have a suggestion?
Our site is heavliy wooded, 85% shade, flat lot and we receive about 40" of rain per year so I am worried about the long term integrity of OSB SIPS.  I have not found a suitable builder yet.  Anyone out there work in the 22101 zip code?
mmacgowaUser is Offline
17 Jun 2007 11:15 AM
tommymac,
You could virtually have any roof done in SIPs but the price tends to get outrageous considering that your ROI might not be recovered. We quote truss roofs for that reason and for the cutup nature of many roof styles. You can get much of the beneift of seal and R value received from SIPs by using spray foam to seal your roof/ceiling joint and then adding blown in to get a higher R value.
Be careful with products like Home Architect, I have learned the hard way that similar programs do not always give you accurate results. So pay to have a designer or architect review them. Finding out that the icon for a spa tup is not correct or that your roof joist measurments are not accurate are important to know before you break ground.
As for your price, there are probably other factors we would need to know to make a good determination. What is your actual shipping cost? Are you going to get a break on labor? or doing it yourself? Is engineering provided, etc. We also don't know where you live and what you plan to save on your future energy costs. I would consider that on the high side in my area as I use raw panels and can get them on site for less then $3/ft.
OSB SIPs should be fine if you find someone who can build and install flashing but steel may be worth an extra price for piece of mind. At least with OSB wall SIPs and a traditional roof, you might find someone who is willing to build them at a regular stick price.
18 Jun 2007 12:27 AM
mmacgowa,
My current thought is to use truss framing with sprayin insulation.  Blown in on top will not work because there is no space.  I will end up with a site built SIP like roof.  Meaning under the shingles will be sheathing, under that will be spray in insulation between the trusses, under that will be the drywall finished ceiling.  I would like to have a way of not having the sprayed insultion adhear to tightly to the roof sheathing just in case it needs to be replaced someday.
18 Jun 2007 01:00 AM
mmacgowa,
Answers to some of your other questions.
On Chief Architect.  You are right.  The software can only do so much and you have to check everything.  I have had to build some things using the CAD mode to get the correct dimensions.  I find the libraries fairly extensive and you can change the dimensions of any item.   I have changed the sizes on all the appliances to match our current selections including clearances.  I correctly sized furniture based on things that we like at the stores and placed them on the plan to see how things fit and clearances.  Auto building the stairs was fast but then I spent a lot of time changing the rise and run. I hate steep stairs.  My wife laid in the electrical plan.  She started with the 'auto build' which lays in the wall sockets to code including specing GFI's in the kitchen and baths.  You still you have to go room by room and adjust the ones that end up in the door and window trim.  She also laid in the can lights based on a free package she got that specs lights based on lumens required for functions in different rooms.  It even shows you where to put them in the ceiling.  It was time and money well spent.  Only dissapointement is the materials list which gives totals for the entire house not by room. Cool part was I built an SIP wall type so it shows how many Sq FT of the stuff I need.  It showed the same number as Thermasteel came up with off the printed plan.  The plans need to get engineering approval and I can send them in AutoCAD format.
Shipping costs are estimated at $1000 for one flatbed traveling a distance of 270 miles.
Do not know about labor costs, not that far along.  Not doing it myself.
SIP Engineering is included in the price as well as all the openings.
I live about ten miles west of the White House. I do not know what I will save in energy costs but the house that is there now is a 1958 rancher with no insulation in the walls, two fireplaces, and the original windows, so I think I will save something.
ablizzUser is Offline
25 Sep 2007 05:22 PM
We too are looking to use Thermasteel panel, although don't quite fully understand the use of it.
Do we still need a house frame with thermasteel ? or does it work like panelized home (such as Eaglenest home). We built Eaglenest home, like it , but quite complex to construct.
25 Sep 2007 08:28 PM
Posted By ablizz on 09/25/2007 5:22 PM
I am wondering how you could consider using a product that you don't understand? Inquiring minds and all of that.
Personally, I would figure out what I'm trying to accomplish and find a product that satisfies the need, instead of trying to force a product into a need that may not be fully defined.
25 Sep 2007 09:44 PM
JC,
I fully agree that needs should be considered before selecting the product. Too many times I have spent too much time trying to use materials already on hand.
26 Sep 2007 05:39 AM
I am a scientist, not a builder.  I was GC for our last house, the only house we built (yet); I was just mostly managing and buyer, the subs were experienced folks eager to help a GC gal.
We just moved to the coast, and want to build "green" house. Came across Thermasteel, read about it energy saving and so on...
Thought some body in this forum may be able to give some tips...
tmsuUser is Offline
26 Sep 2007 08:43 AM
Posted By tommymac on 06/16/2007 10:33 PM
TMac,
My OSB SIPs, with a hip roof, cost around $4.50 per square foot.  I used 6.5" panels for the walls and 8.5" panels on top of a standard truss system (24"O.C.).  This included the engineered plans, holes cut for windows and doors and screws/washers.  The panel measurements were spot on and I was surprised how well the roof went together.  It wasn't super smooth but that was my fault, not the panel manufacturers fault.  A little bit of "carpentry work" made it all good.  My roof panels (not the hip part) were 17' x 8'.  I used a crane to hoist them into place and then screwed them into the trusses.  The pitch of the roof is a 6/12.  This gives me a nice large storage area but not really pratical living space.  I suppose if I had gone with a steeper pitch, that would change.
Anyway, my two cents
Tmsu
26 Sep 2007 09:13 AM
we build hips all the time with our steel SIPs with no fears of building in heavily wooded conditions
lkazanov2User is Offline
26 Sep 2007 04:23 PM
Posted By tmsu on 09/26/2007 8:43 AM
TMac,
Tmsu
TMSU,
Who was your SIP supplier?
Leonard
gameboyUser is Offline
26 Sep 2007 08:22 PM
Thermasteel quoted me over $14.00 a square foot.
Perhaps my project was too complicated, though it sure doesn't seem that way.
Needless to say, I am looking elseware.
tmsuUser is Offline
27 Sep 2007 01:36 AM
Leonard,
My supplier was PorterSIPs out of Holland, MI.  My experience with them was very good.  Granted this was my only experience but their quote was quick, thorough and one of the lower ones I received.  I was welcomed when I asked to tour their facilities and see the manufacturing process.  Nothing fancy but impressive nonetheless.  Their engineering department was easy to work with and the panels were built exactly per spec.  I know that I am blowing sunshine but with all of the other horror stories I have read, these guys deserve the publicity.
Tmsu
davidqxoUser is Offline
21 Jan 2009 03:05 PM
Could you please share with us the name/source for the free package that helps specify lighting? Thanks!
bashfuleddieUser is Offline
08 Feb 2009 06:38 PM
I use structalls steel clad panels they are superior in construction and competitive in price.
Structall's website has details as well as 16 floor plans you can order a pre cut home from.
I have finished five in New Orleans with a HERS score of 60 or less on each showing a 40% reduction in total energy cost.  i.e. a 1277 living with an 1,300.00 annual energy bill.
Be careful sizing your heat pumps 1277 actually required a 1 1/2 ton Heat pump but they do not make a 14Seer model that small so eneded up with 2 ton dual speed system I didn't need just to get energy star label.
Our next home is going to be a Net Zero home and with rebates to homowner will only add 3,200.00 to cost of home.
Eddie
08 Feb 2009 06:41 PM
Ain't nothing bashful about you Eddie, best wishes
08 Feb 2009 06:43 PM
Have you tried the energy star website they have a multitude of resoruces for the ALP package.  I was able to get everything I needed at local Loew's store.
08 Feb 2009 06:47 PM
Hi chris not heard from you in years.
Best Wishes
johncarlUser is Offline
09 Feb 2009 12:18 PM
Hello
We built a Hip Roof using steel hip walls....
The roof itself was 6inch double sided 26 gauge steel panels.  R43 insulation factor.  We had to cut the panels for size.
We eliminated the Roof Trusses by doing this...
John
Superior Home Technology
Attachment: 100_1914.JPG
People Online People Online: Visitors Visitors: 160 Members Members: 0 Total Total: 160
