Insulating Ceramic Backerboards Instead of OSB
Last Post 15 Aug 2007 10:36 PM by slenzen. 6 Replies.
aziansenzationUser is Offline
14 Aug 2007 09:24 PM
Update: This is a cool product from Unifrax
These ceramic boards would be a terrific alternative to OSB or Gypsum. Put that on a SIP and WOW!Apparently they have high R-Value of 1.1 per 0.5 in. These boards were developed to be placed behind oven or kilns so as not to damage materials behind it. Isn't that cool?! The R-Value of that is more than cementboard or Gypsum and probably available to people who operate pottery establishments.
Relative Comparison "R" Values of Substrate Materials per Inch
Ceramic Board 2.2
Gypsum 0.90
Cementious Board 0.40
GFRC 0.048 (As you can see.. a very very poor insulator)
Any discussion on this?
15 Aug 2007 05:07 PM
aziansenzation:
At what temperature is the 1.1 R- value
What is the weight per sq. ft.
Does it have structural capabilities?
What lengths do they come in?
What does one cut it with?
Can it be nailed or screwed?
15 Aug 2007 05:50 PM
Go to www.unifrax.com for more information on their tech and MSDS sheets...
It's their Fibrefrax Duraboard line of products. Being that it's a refractory, it's thermally stable up and above 2600F in certain line. It doesn't say if it's structural but being a rigid product it might be. There are various densities available. They do have castable products and various blanket type insulations. I'm assuming that these ceramics are easily cutable with a diamond blade circular saw. Since it's mounted on walls, screws are always better. Try fibreglass screws ;)
There are other companies with similar ceramic board products. It's just one that I found without all the hype and with tried and true customer base.
There's also a ceramic curtain wall from China from another company...
15 Aug 2007 05:57 PM
Posted By aziansenzation on 08/14/2007 9:24 PM
I'm not really sure why you are so excited? Since most SIPS have less than an inch of 'skin' you would only be gaining around R-1. And at what price?
15 Aug 2007 07:48 PM
aziansenzation;
Easily and cuttable with a diamond blade is an oxy-moron
I'll stick with what I know works
15 Aug 2007 09:13 PM
Diamond 8.5 inch circular saw blades are only $5/here i've cut 2in. granite (w/o water) and it's much harder than ceramic.
Changing people's minds about what works and whats coming is the whole idea of "newer" technologies.. the space shuttle doesn't use a stainless steel skin on it's hull..it's a ceramic.. here the ceramic board is cheap since there's lots of industry here that uses that product.. (precast ceramic is another option too)..perhaps in your region it's not as viable as say a stainless steel SIP..but to some people benefits are that it's looks like stone.. has better perfomance in R value than metal or concrete skin etc.... and repairable when grandmother accidentally drives a car through the wall..:P
in this forum, all i hear are sales pitches from (x) companies but really a consumer have options now to know alternatives, pros and cons, and be non-biased about products..
what is good for me is not necessarily good for you as the saying goes..
We should have an "alternative building system" category here. There are many systems that don't quite fall into the ICF or SIP categories that end up getting discussed in them.
People Online People Online: Visitors Visitors: 259 Members Members: 0 Total Total: 259
