Retrofit foam in exterior walls
Last Post 27 Aug 2007 05:03 PM by PanelCrafters. 1 Replies.
rbeck777User is Offline
27 Aug 2007 02:28 PM
I have some exterior walls exposed due to another project.  I want to replace the crappy fiberglass batt insulation with foam board insulation.  What should I do about a vapor barrier?  Inside or outside surface or none?  If the foam has foil, which way should it face?
Posted By rbeck777 on 08/27/2007 2:28 PM
For a retrofit/remodel like that I would go with spray foam. Google on 'Froth Pak'.
That would depend on your location. Generally in Cold areas the barrier is on the inside. And, with spray foam, you may not need a barrier at all!
Good Luck!
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
