Steel SIPs - Reduce Insurance Premiums
Last Post 12 Nov 2007 06:11 PM by cmkavala. 9 Replies.
08 Nov 2007 05:48 PM
See the attached , from an Insurance Agent who specializes in risk management
Attachment: Insurance flyer.pdf
08 Nov 2007 06:18 PM
Any steel SIPS suppliers, contractors near MN Minneapolis? Where would I go to find them?
mmacgowaUser is Offline
10 Nov 2007 08:46 AM
why the difference between block and steel SIPs? I can see the advantage in steel SIPs over block for energy efficiency but this wouldn't seem to figure in a risk policy for an insurance carrier?
10 Nov 2007 09:35 AM
Posted By mmacgowa on 11/10/2007 8:46 AM
mmagowa;
Are blocks also used for the roof system? No the weak point has always been the connection at the wood truss system. Plus the steel SIPs are rated as non-combustible. hence the lower rates.
10 Nov 2007 07:32 PM
ok. I understand the difference in roofs. Steel and SIP definately has advantages to a point. A firemen once told me of concern regarding steel stud homes when the fire reaches critical point and the steel melts. Apparently they are more of a danger to firemen and people in a burning building near melt down but the fact there is much less to burn in the amount of combustibles and lack of ability to add to the furnace is definately a plus anticipated by the price.
11 Nov 2007 11:36 AM
mmacgowa
I agree with the fireman, but if the fire is hot enough to melt steel studs, there is no chance of saving lives or the structure.
In a steel sip home their are no combustibles in the structural components -  the only way fire could sustain itself would be thru the non-structural components and contents
Bob GUser is Offline
11 Nov 2007 05:19 PM
Hi: Just something from my previous life as a claims manager. What used to be referred to as a class "A" building for insurance purposes was one that was built basically with no combustional construction material. SOG or pan poured concrete, metal framing or concrete tilt up etc.. So my guess is that a Sip with metal would qualifty provided no wood is used in the sub floor or roof. However, please take this with a grain of salt, as I have been out of that business now for 25+ years. Bob
11 Nov 2007 05:47 PM
Bob;
In Florida there is also a "superior" classification that steel SIPs fall into
11 Nov 2007 08:49 PM
From what I understand about fires, you don't want to be in any SIP house with a fire. Hopefully the fire alarms go off and the occupants leave before the 02 is sucked out and the fire extinguishes itself.
From what I understand about fires, you don't want to be in any  house with a fire.
People Online People Online: Visitors Visitors: 277 Members Members: 0 Total Total: 277
