Extra foam or airspace behind drywall?
Last Post 16 Jan 2008 12:25 PM by cmkavala. 9 Replies.
Richard AUser is Offline
13 Jan 2008 06:43 AM
On our new sip house our builder wants to use 3/4" furring strip  between the drywall and sip surface to create space for ease of wiring.  At first I thought I would fill that space with foam boards but reading several confusing paragraphs on  various insulating products available I think I found that 3/4" foam has a R value around 3 (the cheaper stuff) and  3/4" airspace in an insulation stack has only slightly less.  This somehow doesn't seem right to me.  We will use sips with steel framing which is exposed on the surfaces.    Any guidance would be appreciated.  Thanks.
Dick
olpjebUser is Offline
13 Jan 2008 10:02 AM
Dick - I built a house with SIPs, but I am not a SIP expert...but...I believe the above idea is with furring strips is great.
Your SIP wall is the insulator. Adding extra foam just adds more insulation, but do you really want it? You would have gotten the R equivalent of your SIP wall if you were to screw the drywall directly to the SIP wall.
3/4" XPS (not EPS) has a 4 R-value.
DonaldsonUser is Offline
13 Jan 2008 11:40 AM
Dick,
Check with your contractor but if you are using steel clad sips or OSB, I guess it would also work, but I used 1 1/2 " High Hat furring strips on the walls. With 1/2 inch drywall this will give you a two inch space just the right size for using shallow electrical boxes. This will eliminate the need to perforate the was to set the box.
13 Jan 2008 02:08 PM
Posted By Richard A on 01/13/2008 6:43 AM
The foam R-value of about 3 is about right. An airspace(1"-4") is only around R-1 according to ColoradoEnergy.org. Also, something other than air would be a pseudo fire block.
After the electrician has done his thing, I would use the 3/4" foam. A little more R-Value never hurts!
13 Jan 2008 03:35 PM
Dick
Dick;
I don't blame your builder for wanting to do it that way.  It is the way we do it with steel SIPs , using 1-1/2" steel hi-hat as shown on the link
then use a 4" x 4" x 1-1/2" deep box with 1/2" plaster ring  it also saves from cutting skin
just leaving the dead air space will leave insulation value too
13 Jan 2008 04:54 PM
Thanks everyone for the info.  Counting the drywall, sip, siding, and air space the wall comes to about R 25.  With the increase of 2 in R value from foam replacing the air the new total would be about 27 or about 8% better.  The cost of the R 3 foam will be adding something like 0.35% to the cost of the job.  With the cost being in the noise and the benefit not insignificant, I think I'll go for it.
I'll think about the bigger furring strips.  They would double the space lost from 17 to 34 sq ft.   It's a long skinny house, so it's got more wall length to lose inches from than if it were square.  It's going on the same footprint of the one it's replacing only longer in the long dimension and with a second floor added so it has to be skinny.  It has to fit between an existing 600 sq ft room on the back and a 3 car carport on the front.  I'll talk with the electrician and see what I'm trading for that 17 sq ft.
Dick
14 Jan 2008 04:37 AM
Posted By cmkavala on 01/13/2008 3:35 PM
Chris, can you tell us more about those steel joists at that link? Who makes them? What do they cost per lineal foot?
14 Jan 2008 08:09 AM
Posted By Jelly on 01/14/2008 4:37 AM
I don't blame your builder for wanting to do it that way.  It is the way we do it with steel SIPs , using 1-1/2" steel hi-hat as shown on the link[/quote]
Jelly;
Dietrich "trade-ready" floor joists, those in the link are 12" @ 16" oc and clear spanning 22ft.. attached to the inside of the steel skin ( allowing walls to be balloon framed)
I have spanned as far as 29ft @ 19.2" oc with a 14" deep joist, and know that their engineering will allow about a 32ft. clear span @ 16" oc with a 14" joist
Costs:
12" x 16 ga. - 3.40 lft.
12" rim joist - 3.10 lft
14" x 14. ga. - 4.67 lft
14" rim joist -  4.23 lft.
bridging @ .90 each pc.
We use 3/4" t&g plywood decking glued and fastened using a pnuematic gun that shoots nails directly into the steel
blueconUser is Offline
16 Jan 2008 11:23 AM
Regular NM(romex) house wire must be 1" from the surface.
Better check with your electrical inspector or use BX before using 3/4" strapping.
Posted By bluecon on 01/16/2008 11:23 AM
that is 1" passing thru  a stud, where the romex passes thru a  furring strip it must be protected with a "cant-nail" plate.
We do not even need to to that when we use 1-1/2" hi-hat ... gives sufficient clearance as is and has been accepted even in commercial buildings
People Online People Online: Visitors Visitors: 262 Members Members: 0 Total Total: 262
