SIPs in steel frame building
Last Post 11 Mar 2008 07:48 AM by hii. 3 Replies.
hiiUser is Offline
11 Mar 2008 02:52 AM
Is it possible to use SiPs in steel or concrete frame building? What is the maximum height (storey numbers) of the structure in this case?
11 Mar 2008 07:25 AM
If you are using a pre-engineered steel building, then the SIPS would be a non structural skin just as in a timberframe application. The steel main frames and substructures provide all the support. So the building can be whatever size you and your steel engineer design for. A word of caution, most steel building packages are designed with lower dead load ratings. Make sure that yours has an increased dead load rating to compensate for the added weight of the SIPS.
11 Mar 2008 07:30 AM
hii;
With our steel SIPs it is possible to balloon frame 3 stories high, to date we have stood 31 ft. tall wall panels in one solid piece
Posted By hii on 03/11/2008 2:52 AM
hiiUser is Offline
Is it popular to use SIPs in steel building or it is just an exlusion ?
People Online People Online: Visitors Visitors: 172 Members Members: 0 Total Total: 172
