SIP Adhesive
Last Post 11 Jun 2008 08:21 AM by . 3 Replies.
fly840User is Offline
02 Jun 2008 11:12 PM
I have read the tubes of adhesive and see no other suggested uses for this adhesive other than SIPS.  Any chance I can use it for something?  Wood to wood?  Throw it away?  I have a case plus.
Thanks.
The Panel GuyUser is Offline
04 Jun 2008 05:27 PM
The panel mastic is more of a sealant than it is an adhesive. You don't want to use it to try and bond things together. Won't your supplier purchase it back from you ?
I've also used it for external sealing. Where walls butt each other, I run a bead up that inside corner and it always seems to be a spot where the seal isn't as tight as I like it. Sills are the biffest weak point in respects of sealing in SIP systems. I religiously, run a bead at the inside and outside where the cripple is attached to the trimmer. Always seems to be a small gap at that location.
If you're building more projects, use it to seal under your plates.
07 Jun 2008 09:32 AM
Thanks Panel Guy. Good points, I will use it as a sealant. I know I have plenty of places to do that.
NWPUser is Offline
You can use the PL Premium adhesive. It does the wood to wood and foam to wood.
People Online People Online: Visitors Visitors: 166 Members Members: 0 Total Total: 166
