SIP Modular Construction
Last Post 12 Feb 2009 11:12 PM by JeffD. 36 Replies.
egouinUser is Offline
07 Feb 2009 07:49 AM
I'd call the modular factories closest to me and see if they have any recommendations. Likewise, I'd call local architects and see if they are willing to work with modular construction, and if so, which factory they would recommend. I've found that a lot of professionals have have their own preferences and/or pre-conceived notions about modular construction.
Where are you located? If you are in New England, I could make some suggestions. If outside New England, you'll have to go through the above process. Unfortunalty, unless you get lucky, it WILL be a process.
Hope this helps.
Ed
www.GouinGreen.com
http://www.GouinGreen.com<br>Superinsulated SIP/Modular House (HERS = 30)<br>GSHP w/SCW, ERV, Passive Solar, Solar HW
glenfotreUser is Offline
07 Feb 2009 09:17 AM
There is a company in Alberta, Canada that builds SIPs modulars, but I don't recall their name. Shipping costs and duty to AZ was cost prohibitive. Barvista in northern Colorado builds modulars using SIPs only in the gable ends (Premier SIPs) but not in the rest of the home. www.barvistahomes.com I think that it is an excellent idea, but it either amounts to a modular manufacturer adding SIPs production to his factory or partnering with a manufacturer who is nearby.
coddaveUser is Offline
07 Feb 2009 04:17 PM
As an exercise you sould check these guys out.  They are located in Edmonton, AB and they offer EPS SIPs as an option.  Ask them to send you pictures of the 2600 sq. ft. modular they have under construction, I have never seen anything like it.  This modular is not a SIP modular, but it shows you what these guys are capable of.
www.westernmodular.com
bashfuleddieUser is Offline
08 Feb 2009 06:44 PM
How did this work out?
08 Feb 2009 06:55 PM
Have you decided on what type of modular home you want and what region you will be serving.
I think I can give you a couple of sources.
08 Feb 2009 09:59 PM
go to automated builders website they are trade magazine that puts out a guide to manufacturers and consultants. I don't know if they have it listed on website or not.
johncarlUser is Offline
09 Feb 2009 12:08 PM
Hello Carol
I am with Superior Home Technology in Orlando Florida.  We have designed a SIP system.  We use panels whether 4x8, 4x9, or 4x10 that is steel studs 16" on center with foam insulation R30 and Hardie Board on both sides.  The exterior wall is the same as the interior walls.
For the roof we use a 26 gauge double sided 6 inch foam SIPS.  This gives you a R43 insulation factor.
From there it is all finishing work.  We would work with the subs to finish the home from electrical, hvac, plumbing, cabintry etc....
Goes up rather quickly...
The Shell is Exterior Walls, Interior Walls, Attic Floor, and Roof...
I hope this helps......You are usually looking at about 10% higher in cost compared to traditional..
email please for pics and more information.
John Thierry
GeorgiaTomUser is Offline
09 Feb 2009 12:23 PM
johncarl;
are the panels EPS or PU?
09 Feb 2009 07:03 PM
I believe PU
09 Feb 2009 07:06 PM
Is it white foam or yellow?
09 Feb 2009 07:11 PM
I could not find the system under the Florida Product Approval web site is it under another name?
09 Feb 2009 07:44 PM
White
09 Feb 2009 07:47 PM
Please send me email address and I will send you a copy of our Evaluation and Validation Report by 2 Florida PE's who validate that our system meets and exceeds all Florida County building codes.  They are also licensed in 26 other states.  I will also send you pictures of completed projects and houses under construction.
Thanks in advance
09 Feb 2009 08:22 PM
Do they you have a ICCES evaluation for  2006 IRC code compliance?  Some officials require it for use as an alternative means and methods exception.
What is the foam most EPS foams are rated for 4.33 r value per inch.
10 Feb 2009 06:29 AM
Posted By johncarl on 02/09/2009 7:44 PM
White
if its white its EPS not PU
10 Feb 2009 06:40 AM
Posted By bashfuleddie on 02/09/2009 8:22 PM
eddie; what is the foam density of your panel?
Eddie B nice to see you are still carrying the metal SIP torch like I am.
People Online People Online: Visitors Visitors: 278 Members Members: 0 Total Total: 278
