Thermal transfer with Metal Sips?
Last Post 05 Aug 2008 06:06 PM by KwikBuild. 15 Replies.
newhomeUser is Offline
16 Jul 2008 02:56 PM
How is thermal heat transfer handled when Metal SIPS are used for roofing?
I would think that you would have a direct line to the outside in this application.
I am looking at the inner skin going directly over the wall to the outside.
16 Jul 2008 03:06 PM
Posted By newhome on 07/16/2008 2:56 PM
Thermal transfer only happens at the top/ base channels, FSEC have used thermal imaging cameras and found a very thin line on the imagery.
In northern climates it is more of a concern and in those cases thermally broken channels are used, and a 1/4" saw cut  on underside directly over the thermal top cap creates the thermal break.
But again not a concern in the south, the thermal break is only needed in colder climates
rnortmanUser is Offline
16 Jul 2008 03:14 PM
Can somebody post a link to drawing of the details you guys are talking about?  I think I get what the original poster is complaining about, but I'm not sure I'm picturing the solution properly.  A picture is worth a thousand words...
16 Jul 2008 03:19 PM
I would love a diagram as well. I see a problem of cutting into the roof panel?
16 Jul 2008 03:29 PM
Posted By rnortman on 07/16/2008 3:14 PM
attached is a detail for top cap we did for someone in Russia
Attachment: Thermal cap.PDF
03 Aug 2008 05:29 PM
What about at the window and door openings? If the rough openings are lined with steel isn't there a thermal transfer possibility there?
03 Aug 2008 05:35 PM
Posted By Jelly on 08/03/2008 5:29 PM
jelly;
if you run the steel straight thru, but in extreme cold climates the window / door recievers are either thermally broken or 2 piece with gap, same as done for base or top channels. exterior wall corners are mitered so there is no thermal transfer
03 Aug 2008 05:41 PM
cmkavala, are you talking about the window or door frame as provided by the window/door manufacturer, or about the framing put into the rough opening by the SIPs manufacturer?  I had been assuming that even steel SIPs use 2x lumber for framing rough openings, but perhaps I was wrong.
03 Aug 2008 06:02 PM
Posted By rnortman on 08/03/2008 5:41 PM
wood in steel SIPs, bite your tongue!
the attachment shows the channel used for steel sip walls, and 18 ga. "U" channel, no grooving necessary, it just simply wraps the opening and is effective for openings up to 6ft. wide, larger  - such as overhead door openings have another detail
The overhead door detail also serves as the top door buck, sides are done with 6" steel stud/track
The photo shows the window framing
Attachment: File0241.PDF
Attachment: OH door.PDF
Attachment: Heilicka......Peepels 006.JPG
04 Aug 2008 09:56 AM
Posted By cmkavala on 08/03/2008 5:35 PM
I thought you were doing butt joints on the exterior corners?
ReadyToRetireUser is Offline
04 Aug 2008 04:43 PM
That saw cut on the underside of the roof panels would create a very easy thermal break.  But if storms are a concern, wouldn't that cut completely eliminate the SIP's strength against uplift on the overhangs?  How do you protect the overhang?
Very respectfully,
Larry
04 Aug 2008 05:25 PM
Posted By Jelly on 08/04/2008 9:56 AM
Jelly;
butt joints in the south mitered in the extreme cold north,
04 Aug 2008 05:32 PM
Posted By ReadyToRetire on 08/04/2008 4:43 PM
Very respectfully,
Larry
Larry;
 Not completely,   screws are on the outside wall perimeter and each screw has an 1-1/2" OD fender washer @ 8" oc ....... engineers say its OK. Can't imagine uplift that great.
Screws with washer will not pull thru steel skin, I can however drive a SIP screw thru an OSB panel as they do not use washers
04 Aug 2008 07:36 PM
Larry, which saw cut are you referring to - is it in one of the details or the photograph?
05 Aug 2008 04:13 PM
Jelly,
Oops --  I was referring back to the image linked in Chris' 07/16/2008 2:29 PM posting, which is the 5th one in this thread.  It shows a steel SIP roof panel with a lateral cut to create a simple thermal break.
http://www.greenbuildingtalk.com/desktopmodules/ntforums/viewer.aspx?portalid=0&moduleid=369&attachid=528
Sorry for the confusion.
Very respectfully,
Larry
KwikBuildUser is Offline
I tried to paste a picture of what our panels look like and how they prevent "Thermal transfer" but this system will not let me cut and paste to it.
Take a look at our web site link  We do have details show our panel system.  These panels can be used for walls, floors & roofs.
Kwik-Build Panels
People Online People Online: Visitors Visitors: 262 Members Members: 0 Total Total: 262
