roof panel chases - Electrical ??
Last Post 12 Aug 2008 04:16 PM by gregj. 6 Replies.
07 Aug 2008 06:04 PM
Question to electricians............
if romex is to be a certain distance back from ceiling for nail/screw protection, how would chase comply with the code if distance is just 7/16"?
Attachment: Bianco 017.JPG
rnortmanUser is Offline
07 Aug 2008 06:39 PM
Perhaps armored cable (bx) or a metal guard plate would do the trick.  A bit more expensive than romex, though.
12 Aug 2008 02:18 PM
Detail & note taken from set of OSB plans
Attachment: Scan10005.JPG
Louie FischerSIPs User is Offline
12 Aug 2008 02:54 PM
We'll put wire chases anywhere they are requested. It is a simple matter of hot wiring the chase as per customer specifications before the panel is laminated. I had a customer that wanted it this way because it is supposed to be more energy efficient. However, if code requires a chase to be in the center of the EPS core then we can do that. I would imagine that most OSB sip manufacturers offer this service as well.
gregjUser is Offline
12 Aug 2008 03:06 PM
Do you have the specific wording for that section of the NEC? Seems like it only pertained to a setback at the joist/stud location not everywhere. Since there is no joist/stud adjacent to the chase then it doesn't apply. But it's just a vague memory ......
12 Aug 2008 03:41 PM
Posted By gregj on 08/12/2008 3:06 PM
Gregj;
I think the dimension was 1-1/4" clearance, but we are always at the mercy of the inspector's interpretaion of the code and how they would view the SIP as a structural component. Ultimately the wire is not protected well.
With that particular chase detail the romex is suceptable to being hit with screws
Posted By cmkavala on 08/12/2008 3:41 PM
So very, very true.
I suppose one could insert a long thin piece of steel "lath" into the chase next to the OSB before final assembly as a guard.
People Online People Online: Visitors Visitors: 279 Members Members: 0 Total Total: 279
