Posted By Paulcf on 08/15/2008 11:53 PM
Your conventional lumber framing will introduce thermal bridging and thus reduce your R value. We did a house in Colorado with spray in. It was a nightmare. The studs continued to shrink and twist and it caused very small gaps to open up. Invariably the vapor barrier wasn't perfect so warm humid air entered and started condensing as the dew point was inside. This caused occasional drops of water to fall even from the ceiling! We had to remove the ceiling and scrape out the foam and put in fibreglass and sealed it up.
We're located in Alberta so it's no value for you to obtain our SIPs when there's plenty of SIPs companies in the New England area (I'm assuming!). Good luck.
I've never heard of that problem with spray in foam. What kind of foam was it? Foam usually sticks like glue to lumber and has some flex so I would have thought it would stay adhered with the wood even with some movement. Have others on here experienced that problem?
I understand that closed cell foams are considered a vapor barrier once they are 2" thick but I doubt that open cell forms are considered a vapor barrier at all for ceiling use. Perhaps the foam you used wasn't a vapor barrier at all and a vapor barrier should have been used with it?
Whether the problem was losing the vapor barrier due to separation of the foam from the ceiling joists or from use of open cell foam I would have thought it would make more sense to apply an additional vapor barrier to the bottom of the ceiling rather than ripping the ceiling down and removing the expensive well insulating foam. The fiberglass will certainly not seal better than the foam. That would be like throwing away a Cadillac and buying a new Focus if the tires went flat.
