StoGuard and Cedar Breather
Last Post 16 Sep 2008 11:44 AM by TFreidman. 3 Replies.
CathyKUser is Offline
02 Sep 2008 06:47 AM
Has anyone had any experience with either?  We were told we could use Cedar Breather between OSB SIP roof and the metal roofing we want to use.  The StoGuard is a spray-on vapor barrier and is supposed to be ideal with SIP.  Thanks.  Cathy
rnortmanUser is Offline
02 Sep 2008 09:23 AM
Haven't heard of either of those before, but they both look like they would do what I mentioned in the other thread.  StoGuard is not actually a vapor barrier according to their website -- it's a water/air barrier, but it's vapor permeable, which is perfect for your roof.  You'd need furring strips or purlins over it to provide the ventilation/drainage space.  Looks like Cedar Breather is an alternative to furring/purlin strips.  I know there are other brands of that sort of drainage mat out there as well.  I think you still want the air/water barrier underneath it (like StoGuard, Tyvek, building felt).
thermasaveUser is Offline
16 Sep 2008 10:11 AM
Hi Cathy:  I am curious as to why the SIPS you are using are made with OSB.  Our product is made from cement board and is not subject to moisture problems.
TFreidmanUser is Offline
thermasave;
what is the cement board , hardi or another cement substrate?
