Alexcostariha
cmkavala
| 10 Sep 2008 06:48 AM |
Posted By Alexcostariha on 09/10/2008 4:05 AM Hi, anybody knows something about what a trouble can mouses be when you build with SIPs ? I was spoken mouses very like to eat and live at SIPs.
Alex; I have heard of that happening, if you built with steel SIPs it would not likely occur |
jusaxeme
| 10 Sep 2008 06:12 PM |
I already responded but it looks like the response got removed. Must not be popular to concur with your observation. Mice LOVE to burrow into the EPS if it is left unexposed for very long. They cannot get through the concrete--unless you have honecombs which you will hardly ever know about--the other thing ICF people do not want to talk about. ICF is always better than stick built but still there are issues that need to be admitted to and dealt with like an adult--not like an ostrich by not looking at it.
cmkavala
| 10 Sep 2008 06:17 PM |
ICFs are also prone to termite and carpenter ant infestation |
TLC-ICF
| 10 Sep 2008 08:02 PM |
Posted By cmkavala on 09/10/2008 6:17 PM ICFs are also prone to termite and carpenter ant infestation Can you back this up, where is the food source in the ICF's. Do you not think mice live in hollow wall framing??????????????????????????/
rnortman
| 10 Sep 2008 08:56 PM |
A food source is not necessary. Foam makes a nice home for critters. It is true of ICF foam as well as SIP foam. Of course, ICF foam is on the outside. Easier for the critters to get to. Nobody is talking about hollow wall framing here. (Well, actually, cmkavala does like to fur out the interior walls of his steel SIPs, last I heard.)
Alexcostariha
| 11 Sep 2008 02:34 AM |
When I posted about mouses (and rats also) I wanted to here anybody owning SIPs houses not hearin but dealing with the problem. I can suppose MANUFACTURES add something at foam against those ones. For other hand may be exist some good methods of fighting against it ? I live at Russia and SIPs are new for us. Men wanting to buy hoses with SIPs put answes about this trouble. I think that mouses and rats inhabit anywhere. I think also that the more at South the more these animals getting in all. Therefore you must have answes about this subject. Thank you ! |
cmkavala
| 11 Sep 2008 06:56 AM |
Posted By TLC-ICF on 09/10/2008 8:02 PM
Posted By cmkavala on 09/10/2008 6:17 PM ICFs are also prone to termite and carpenter ant infestation[/quote] Can you back this up, where is the food source in the ICF's. Do you not think mice live in hollow wall framing??????????????????????????/
If you send me a private e mail I'll give you the name, address and phone # of an ICF homeowner with termite infestation. The reason he decided to build with steel SIPs/perform-guard foam on his current construction Yes mice do live in hollow wall framing,but whats the point? termites and ants use the foam as nesting, then travel into the house for any wood based food source |
cmkavala
| 11 Sep 2008 06:59 AM |
Posted By Alexcostariha on 09/11/2008 2:34 AM
. Therefore you must have answes about this subject. Thank you ! The answer is steel |
cmkavala
| 11 Sep 2008 07:09 AM |
Posted By rnortman on 09/10/2008 8:56 PM A food source is not necessary. Foam makes a nice home for critters. It is true of ICF foam as well as SIP foam. Of course, ICF foam is on the outside. Easier for the critters to get to. Nobody is talking about hollow wall framing here. (Well, actually, cmkavala does like to fur out the interior walls of his steel SIPs, last I heard.)
Yes, we do fur-out the sip wall, but at least a mouse cannot get in to eat the foam core, its encased by two steel skins and the foam is borate treated to prevent insect infestation and nesting. Many ICFs go right below grade allowing a perfect runway for critters Having lived in a steel sip home for some time, I can tell you that the occurance of any insect is much less. And there is no organic material to promote mold growth on the structural members. |
Jelly
| 11 Sep 2008 10:38 AM |
Chris, I'm curious about the connection between the slab and the steel track that the SIPS panels rest in. If the track is just screwed down it seems like a perfect place for cockroaches to slip in. But I don't know - maybe there is a layer of construction adhesive or silicone caulk or something? How do you manage that detail? |
rnortman
| 11 Sep 2008 12:47 PM |
Posted By Jelly on 09/11/2008 10:38 AM Chris, I'm curious about the connection between the slab and the steel track that the SIPS panels rest in. If the track is just screwed down it seems like a perfect place for cockroaches to slip in. But I don't know - maybe there is a layer of construction adhesive or silicone caulk or something? How do you manage that detail?
When in doubt, squirt some goop in there. It fixes everything. Better than duct tape even! More seriously, be careful what adhesives you use, especially when touching masonry below, on, or near grade. Some of them are like mold candy. (Some of the early OSB resins were perfect food for mold when combined with the wood cellulose. It's a little better these days, especially with exterior grade OSB.) None of them resist hardening and cracking forever, though if protected from UV and freeze/thaw many will last longer than the materials they're holding together. |
cmkavala
| 11 Sep 2008 01:04 PM |
Posted By Jelly on 09/11/2008 10:38 AM Chris, I'm curious about the connection between the slab and the steel track that the SIPS panels rest in. If the track is just screwed down it seems like a perfect place for cockroaches to slip in. But I don't know - maybe there is a layer of construction adhesive or silicone caulk or something? How do you manage that detail? Jelly; I thought I sent you the whole set of details, but anyway here is the base track detail I prefer expanding foam on the slab as it compensates for irregularities in the slab |
Attachment: base track.PDF
Jelly
| 11 Sep 2008 02:12 PM |
Forgive me, I actually do have all the details, somewhere with all the rest of my belongings in a 40 foot shipping container which I should receive on Monday, along with 4 large German tilt-turn windows I ordered special with 70/40 glass!
So what are the best elastomeric sealants? Opinions? rnortman? |
rnortman
| 11 Sep 2008 02:56 PM |
Posted By Jelly on 09/11/2008 2:12 PM Forgive me, I actually do have all the details, somewhere with all the rest of my belongings in a 40 foot shipping container which I should receive on Monday, along with 4 large German tilt-turn windows I ordered special with 70/40 glass!
Don't make the mistake of thinking I'm an expert. I've got book learnin' but not a lot of experience under my belt. Anything that bills itself as a sealant should not be mold candy; it's adhesives (specifically glues) that can be a food source. Latex, silicone, and polyurethane are all good. I am particularly intrigued by the flexible expanding foams; there are latex expanding foams now that remain spongy even after curing, which allows for thermal expansion and some structural settling without creating cracks. The latex foams are open-celled, meaning they will only slow water vapor down slightly, not stop it. They can even wick moisture. The "window and door" version of DOW Great Stuff is a closed-cell polyurethane that remains flexible after curing. That sounds great to me on paper. But I haven't tested it myself in the field. (The normal Great Stuff cures rigid. It clings tenaciously, but it will only give so much before it tears.) The silicone and latex/silicone hybrids have come a long way in terms of remaining flexible for a long time, I guess, but they don't expand like foams do. Maybe somebody with more experience can speak up with some recommendations. |
cmkavala
Alton
| 11 Sep 2008 04:31 PM |
What about using 3/8" polyethylene sill sealer under metal tracks? It is compressible and recommended for use under wood sill plates. I believe the cost should be less. Do you see any problems with sill sealer under metal tracks? |
cmkavala
| 11 Sep 2008 04:45 PM |
Posted By Alton on 09/11/2008 4:31 PM
What about using 3/8" polyethylene sill sealer under metal tracks? It is compressible and recommended for use under wood sill plates. I believe the cost should be less. Do you see any problems with sill sealer under metal tracks? Alton; I have never done it, but certainly it would be OK. I look for the easiest way and so far a bead of expanding foam has worked for us, if it was on a deck , then would use a sealant in a tube. |
Alexcostariha
| 12 Sep 2008 12:15 PM |
Hi, fellows ! It is wery ineresting all you are speaking about . But you deviate from the subject lightly, aren't you ? Let us will speaking about SIPs made with OSB-3 sheets and EPS core only such as here for example http://www.iaosb.com/assets/images/SIPA_20Detail.jpg ore here http://www.ferrierbuilders.com/SIPhouse2Com.jpg
I want repeat my question.
HAVE SOMEBODY ANY EXPRIENSE OF LIVING FOR A LONG TIME AT HOME MADE WITH THE SIPs ? DO THEY RESIST WELL FROM MICE AND RATS ? IF I SHALL WANT acquire a pair of hens or rabbits or some other green building's friends shouldn't mice or rats made my home like a sieve ? Every automn I see AS mice run towards my home ( I live at residental home) because home meanse warm and refuge for them. WILL they do eat all my SIP( made with OSB-3 and EPS) house inside after some period of time? Does anybody know about some kind of additives for EPS against critters ? Thank you
GeorgiaTom
| 12 Sep 2008 01:01 PM |
The answer was stated previously ....steel skin with EPS foam core treated with borate (not Borat) is the solution OSB is good for critter food |
