Sips second floor connection
Last Post 21 Oct 2008 11:03 PM by jdofboise. 5 Replies.
jdofboiseUser is Offline
20 Oct 2008 10:27 PM
I am in the early stages of design and am considering SIPS construction. Currently my design is for the main floor to have a "loft" type look with a steel web floor joist supporting the second floor.
Now considering that panels are 4'x8' and I want 10' ceilings on the main floor only (or the bottom of the second floor would be 10') .
- What are my methods of connection for the 2nd floor system to the walls?
      My thoughts are to set the floor joists rim on top of the 1st floor wall thus
      making up my 10' ceiling height. Then set the second floor wall on top of the
      floor system. Are there other methods when considering SIPS?
- I read a thread here a while back (can't find it now) that keeping my dimensions
  on  4' increments eliminates waste and cost when constructing panels. I'm sure
  that I also read somewhere that you can cut costs on the second floor panels by
  specifying 4'-6' high walls and set your wall pitch at a steeper angle 5/12 or better.
  If I did indeed read the part about second floor wall heights and roof pitch how
  does this reduce costs if you're trying to follow the 4' increments rule?
Jerry Logan
Boise, Idaho
21 Oct 2008 07:43 AM
Posted By jdofboise on 10/20/2008 10:27 PM
Jerry Logan
Boise, Idaho
Jerry;
attached is a design we use for metal SIPs / dietrich steel joists, but  a similar design could be done for OSB.
We prefer to balloon frame (instead of stack) the exterior walls for the greatest thermal and air infiltration efficiency, for loft/ 2-3 story designs.
The marinoware steel joist could be done the same
Attachment: joist connection.pdf
21 Oct 2008 02:21 PM
Those would be 'stock' panels. Most manufacturers can make custom sizes. Also, other 'stock' sizes are 4' x 10' and 4' x 12'. Multiple options there!
For thermal efficiency, I would hang the joists from the top of the SIP wall. So. for instance if you really wanted that 10' ceiling, you could use 11' high SIP panels and hang the wall from that. Assuming a 12" high truss, you would get that 10' ceiling.
That is always a good idea, but if that doesn't work with your design, there is no need to force it. If you are fabricating your own panels, the 4' design widths will probably save you some effort and waste. If the manufacturer is doing the work, it usually doesn't matter as they can create custom sizes and minimize waste.
I'm not sure that I understand what you are saying. Maybe they are suggesting to use the short walls and a steep roof pitch to gain useable space with less panels? And, please remember, the "4' Rule/Idea/Whatever" is mostly for widths, not lengths.
KwikBuildUser is Offline
21 Oct 2008 06:09 PM
jdoboise,
The guy are right, the best way and get the best thermo brake is to ledger the floor joist. If you are looking for a 10'ceiling you can use 4'x11' or 4'x12' panels. I like the idea of the steel web floor joist, makes it very easy to get your mechanical, plumbing etc through with out a lot of heading out!
They make a steel web floor truss that is top cord hung, but I have used them only on commerical projects.
David, Kwik-Build Panels
21 Oct 2008 10:59 PM
Posted By PanelCrafters on 10/21/2008 2:21 PM
Thanks for the clarification.
I think you're right it is just for usable space.
Thanks for all the answers and the details guys. This forum has enlightened me a good deal. Keep up the good work.
Jerry
People Online People Online: Visitors Visitors: 190 Members Members: 0 Total Total: 190
