Electrical wiring ideas
Last Post 28 Oct 2008 12:29 PM by tmsu. 2 Replies.
jdofboiseUser is Offline
27 Oct 2008 02:44 PM
I mentioned in a previous post that I was trying to design a home so that it had a "Loft" style feel to it with open steel trusses supporting the roof or second floor. I understand the wiring process a bit in SIPS, but could use some more help with specifics. Keeping in mind that my entire main floor is open, and the above structure is supported by posts I want to run my electrical in either steel conduit or some type of conduit to conceal it (mostly for management) but want it to also be "exposed" in terms of keeping the "Loft" feel on the main floor. There would be a cost concern that would override this type of install if it's way out of hand.
- When completing electrical wiring what are the SOPs (standard Operating Procedures) of installing in a SIPS. - Power Panel in the garage or basement (basement is still under consideration).                                              - I will have a second floor.
Jerry
rnortmanUser is Offline
27 Oct 2008 05:33 PM
Posted By jdofboise on 10/27/2008 2:44 PM
Jerry
Most people would advise against actually recessing the breaker panel into a SIP wall.  Generally you'd build a 2x4 wall on the inside of the SIP wall and put the panel and wiring into that.  If you like the exposed look, you can surface mount the breaker panel, but then I think code will require metal conduit or armored cable coming out of the panel and up to the ceiling (or down to the floor, if you have cable running that way).  Even if code does not require it, I think it would be advisable.  And it will definitely add to the cost, both in materials and labor.  On the other hand, accessible wiring is nice for maintenance and remodeling later on, and exposed plumbing and duct work even more so.  But you will pay more for it if you want it to look nice.
tmsuUser is Offline
I ended up putting my breaker box on the first floor versus the basement. Very convenient if you have the space. I mounted it on the outside of the SIP and boxed it in (inside a walk-in pantery). This also makes it easy to run all your runs first and then box in later. Obviously, code will dictate some of what you do. 36" clear in from of the box was necessary in my area.
People Online People Online: Visitors Visitors: 165 Members Members: 0 Total Total: 165
