Siding Options For OSB SIPS
Last Post 04 Sep 2009 05:36 AM by cmkavala. 15 Replies.
tlynchUser is Offline
20 Nov 2008 03:20 PM
There have been many options discussed in this forum including -
Wind / Rain Screen:
Stucco
Hardie Plank / Panel
Metal - Corrugated and other profiles
Clapboard
Wood Shingles
Vinyl
Board and Batten
Brick
Underlayment:
Tyvek
Felt
And Furring Strips / No Furring Strips
Again, if you have knowledge of any method, please fill out the fields below and if we get adequate information, I will compile it into an article.
SIDING TYPE:____________________________________
INSTALLATION OVERVIEW OVER OSB SIP:_____________________
TOTAL COST OF INSTALLATION - MATERIALS AND LABOR:________________
INTERNET REFERENCES / PRODUCT SOURCES:__________________
COMMENTS:____________________________
20 Nov 2008 05:20 PM
You forgot to mention brick. In essence any type of siding that can be used on a building can be used on a SIPS structure. Every type of finish siding has its own installation process, and that process doesn't vary that much when using SIPS. There are many variations for each type of siding, but the bottom line is: do what needs to be done to keep moisture away from your structure, and if it gets to the structure, give it a way out.
21 Nov 2008 05:03 PM
There are differences though compared to a standard stud install:
1) There are no wood or metal studs to nail or screw into.
2) The OSB layer is not easily replaceable, so water infiltration can cause problems than are very difficult to repair.
Because of these issues, I have found that preferred methods for most siding types over OSB SIPS include Tyvek and vertical furring strips.
kevinbourlandUser is Offline
23 Nov 2008 08:25 AM
I used vinyl and Nova Brick. Both worked great. If you are doing it yourself, these are bothe great options, the Nova Brick really cut the outside noise down a lot, but really keeps the wall hot till late in the night during the Summer.
Kevin
cabinboyUser is Offline
02 Dec 2008 10:52 AM
We used lap siding cedar along with some board and batten for accented walls. No furring strips. We put Tyvek on first, then screwed everything into the SIP panels with Deckmate screws of the appropriate color (designed for use with synthetic decks, they will not deteriorate). We caulked all seams and around windows.
Attachment: Garage-side.jpg
sidingmasterUser is Offline
22 Dec 2008 09:41 PM
I found this new product that would work great for sip
Attachment: steel furring strip.jpg
23 Dec 2008 07:52 AM
Posted By sidingmaster on 12/22/2008 9:41 PM
looks like steel strapping?
ReadyToRetireUser is Offline
25 Dec 2008 05:29 PM
I, also, wish that Sidingmaster would identify the product.
It looks as if it has very regular spots with spacing about the same as the siding's width:  The spots might be attachment points.  If so, it might speed siding installation once it is up.  IF  that's what it is:
How does the time saved putting up the siding compare with the time needed to install the strips? And,
And how many different spacings are available?
Very respectfully,
Larry
31 Aug 2009 04:07 PM
Found this great photo on Flickr-
Hardi lap siding, variable width, over tyvek.
31 Aug 2009 04:21 PM
Posted By tlynch on 08/31/2009 4:07 PM
Its a joke, right?
31 Aug 2009 04:29 PM
I don't understand your comment - what about it do you find funny and why don't you take it seriously?
TorbenUser is Offline
31 Aug 2009 05:08 PM
This picture is from one of the 100K house projects (Philadelphia).
http://www.100khouse.com/
I thought these achieved LEED Platinum.  They list the lap siding as CertainTeed not Hardi.
31 Aug 2009 05:19 PM
You are correct, it is the one of the 100k house projects, I think it is their passive solar house.
passive house
And you are also correct, it is certainteed, I had read this: hardi , but it must be out of date.
Here is another house they finished:
pixel
31 Aug 2009 05:54 PM
Posted By tlynch on 08/31/2009 4:29 PM
Its not the variable width ...............its the crooked lines, its the no corner posts to close in the corners, its the no trim around the recessed widows? and the contiuous butt joint to the left of the no trespassing sign.
The tyvek looks good though , except for the big hole
03 Sep 2009 01:11 PM
pixel
That pixel siding look is interesting. Do you know how they finished the vertical seams? Hardi-panel installation instructions call for battens, caulk, or H-channel on the vertical seams and Z-furring at the horizontal seams. (I gather this is Certainteed and not Hardi, but installation is bound to be similar right?)
But they seem to have achieved a rather clean look, but the photo *is* taken from far away.
Jelly;
not sure what they are using you could obtain  a similar look with a hidden fastener  metal building panel, if you want the varrigated look, you could use 2 different shades.
You may find a company that has "seconds" available
People Online People Online: Visitors Visitors: 281 Members Members: 0 Total Total: 281
