Alton
| 30 Dec 2008 11:56 AM |
Here is a web site for a product that reduces sound transmissions: http://www.acoustiblok.com/
I saw this demonstrated at the International Builders Show in Orlando. It was quite convincing. I wonder if it would work with furred out SIPS? |
MarkosWoodWorking
| 30 Dec 2008 12:50 PM |
This looks like, essentially, a rubber-type mat? Seems to do the same thing as Green glue; converts sound energy into heat. I wonder how it could compare cost-wise, per square foor of coverage?
According to information exchanged with Ted in the other thread, you'd likely be better off not having the space at all, unless it's at least (as per Ted's instructions) 2 1/2".
Of course, the nice thing about this Acoustiblok is that they're showing it right up against the studs. Green glue needs to be sandwiched inbetween two hard porous surfaces. If noise transmission (and floor space) were really an issue, I suppose you could use (from outside to inside):
Drywall/Green glue/Drywall/Acoustiblok/stud wall/acoustiblok/drywall/green glue/drywall? |
| Matthew Sokalski<br>Markos WoodWorking,<br>Akasu Contracting and Consulting (Attr.) |
Jelly
| 30 Dec 2008 02:00 PM |
Funny, acoustiblok also make a sound proofing panel which looks a lot like a steel SIP!? |
Dick Mills
| 30 Dec 2008 04:22 PM |
Acoustiblok is a mass loaded vinyl material. There are several manufacturers, and retail prices generally are in the $1.10 to $2.00 psf. |
MarkosWoodWorking
| 30 Dec 2008 11:01 PM |
It's mass loaded vinyl? I thought I saw a comparison on the website, saying why Acoustiblok is better than MLV?
If it IS a mass loaded vinyl, I don't think I would even bother with it. I think I would rather spare the extra 6" of floor space to put another 2x4 wall than use that stuff. It certainly helps, but I've been in a room constructed with MLV...it was actually sort of pathetic. Much like the polystyrene timberframe SIP home I was in (in regards to sound transmission)...pathetic. |
Dick Mills
| 31 Dec 2008 12:31 AM |
Yeah, Matthew, if you look through the documents on their site, they define the product as a MLV. They claim that they have some special "proprietary" formulation, but it's still MLV.
http://www.acoustiblok.com/3part/AB_3partSpec_ver_01.8.pdf |
MarkosWoodWorking
| 31 Dec 2008 09:08 AM |
Well, I suppose it would still help...Personally though, I think I'd just rather add another layer of drywall with green glue.
I wonder, if a fellow could put rubber isolation strips on the studs before the drywall goes up, what sort of difference that would make. |
