Structural Insulated Panels (SIPs)
sips with block & beam, ground & 1st floor floors?
Last Post 06 Mar 2009 02:23 PM by
thagreen
. 4 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
collectors
06 Mar 2009 12:43 AM
<!--[if gte mso 9]>
Normal
0
false
false
false
EN-GB
X-NONE
X-NONE
MicrosoftInternetExplorer4
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0cm; margin-right:0cm; margin-bottom:10.0pt; margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> <!--[if gte mso 10]> Hi, i have been trying to find some info on building with SIP,s in conjunction with concrete block & beam flooring. (Ground & 1
st
floors) There is no problem with the ground floor as we could of built straight off the block & beam ground floor& gone right to the roof.
But we would like concrete (Block & beam) floor on the 1
st
floor as well. So this will involve building internal walls in heavy duty concrete block/bricks to support the 1
st
floor block & beam.
Can you see any problems with having a cavity as in the diagram? We was a bit worried on how to vent the cavity & the possibility of condensation build up.
(I know the DP is showing in the wrong place. lol)
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
Attachment: sip-cavity.jpg
newsie23
06 Mar 2009 08:46 AM
Not being an expert - my suggestion would be to fill the cavity with fiberglass insulation, vented to the interrior, top and bottom. I equate fiberglass to a 'furnace filter' - giving a degree of convection, air movement. Possibly, leave an open area, around the wall, at the vent level I also think the foundation should be higher than the ground level.
Brawler
06 Mar 2009 09:35 AM
collector, just curious why the block floor. It seems alittle complicated.
collectors
06 Mar 2009 11:08 AM
Posted By Brawler on 03/06/2009 9:35 AM
collector, just curious why the block floor. It seems a little complicated.
Mainly to do with sound (Instruments). We cant get the same values with timber.
thagreen
Have you thought of light-weight concrete ? Or other cement floor alternatives, not to contredict you just no one mentioned it yet. Also cutting sound transmitance can be achieved w/well insul ceiling. Sound will transmit from walking on but almost none going up.
Cheers!
Membership:
croccohvacusa
People Online:
