Structural Insulated Panels (SIPs)
Green roof over SIPs
Last Post 12 Dec 2009 10:28 PM by
CaseyR
. 7 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
loweep
11 Jul 2009 02:01 PM
I was wondering if anybody has done, or has recommendations about, a green roof over a SIP roof.
We're planning to use steel SIPs to put a low-pitch flat roof on an existing brick 2-story building (25'x30'). Green roof would be ~4 inches of soil / plants. Load would be ~25 lbs per sq.ft. We're debating between using modular trays to contain the soil or putting it straight on the roof (with membrane or metal roofing over SIP surface).
cmkavala
11 Jul 2009 02:21 PM
loweep;
we just completed a large sundeck over steel SIPs, it sounds like you will need a surface for foot traffic as well as the loading, we laminated 5/16" hardi to the steel skin then subcontracted for a fiberglass deck / with tan gel coat. It turned out very nice
Chris Kavala<br>
[email protected]
<br>1-877-321-SIPS<br />
SimonD
12 Jul 2009 11:06 PM
I'm not an engineer and I don't know your location's/region's weather characteristics, but 25#/SF sounds a little low for the load your roof will be resisting. Best to think worse case with something out of the ordinary like this.
Tell us where your project is.
Building Designer<br>PANELfusion, LLC, Tampa, FL<br>simon@panelfusion(dot com)<br>"Metal SIP Advocate"
loweep
13 Jul 2009 06:37 PM
25 lbs/sq.ft is a typical number I see given for the weight of a 4in green roof. I will be having an engineer look at everything.
The house is in Houston. Anybody else built with steel SIPs in the area?
SimonD
15 Jul 2009 03:57 PM
My thought is that you don't want any soil or runoff from soil coming in contact with the metal SIPs or any metal roofing. Soil is corrosive and will definitely corrode your roof fasteners and then eventually your metal roofing/SIPs. A membrane that covers over everything, fasteners & all, seems like the durable way to go in my opinion. But anchoring your foliage and not compromising the membrane is the tricky part.
Don't know if you get heavy wind/rain storms in Houston, but they may suck plants off your roof or hold too much water on the roof. Good drainage and securing the foliage are definitely design priorities.
ICFconstruction
18 Jul 2009 08:09 AM
Here in MN we are 45 -50# sf just for snow. You need strong heavy walls to support a heavy roof.
cmkavala
18 Jul 2009 08:25 AM
Posted By ICFconstruction on 07/18/2009 8:09 AM
Being that most SIP walls are 2.5 to 3 times stronger than frame.. no problem!
Chris Kavala<br>
[email protected]
CaseyR
There is a lot of information on green roofs on the Web. Doing a search on "green roof details" or just "green roof" will give you a lot information.
One example is http://www.greenroofs.com/
Green roofs are general made up of a number of layers between the planting media and the underlying roof surface. A typical sequence can be found at:
http://www.hadj.net/green-roofs/assemblies.html
The figure of 25 psf appears to be commonly used for green roofs of about 4" depth when using light weight growing media and lightweight components under the soil. However, when figuring roof loading, you will also need snow loading and/or live load. In our area (north central Oregon) snow load is 25 psf for a total design requirement of 50 psf with the four inches of soil. Your structural engineer will know (or find out) these figures, including wind loading and other factors.
Membership:
croccohvacusa
People Online:
