SIP for Trailer Walls?
Last Post 27 Sep 2010 07:22 PM by ls7corvete. 8 Replies.
woodlabUser is Offline
19 Jul 2009 11:53 PM
I have been thinking about building an enclosed trailer for a fish house. Everything I find on trailer construction seems to be typical stick frame construction for the walls on a trailer. Is there any reason that I couldn't use SIPs for the walls and roof of my fish house trailer? It seems like they should be superior to frame style construction for trailers (even the metal frame ones). Are there any gotchas I'm just not seeing?
20 Jul 2009 04:51 AM
Wood lab;
your not the the first to do this, there are many fishing camps on the Louisiana Bayou, made with metal sips, they are made as thin as thin as 2"
I use the 2" for hurricane shutters on my home
20 Jul 2009 08:56 AM
So there wouldn't be any structural issue with using them for a mobile structure, correct? I was thinking of using an 8x16ish sized trailer with a standing metal seam roof (maybe even a PV roof since I'll need all the power I can get). I didn't know they made 2" sips. Can you point me to what you suggested?
20 Jul 2009 01:06 PM
woodlab;
depending on where you are at we can furnish thru Sip Supply Inc.,  email direct at [email protected]
SimonDUser is Offline
24 Jul 2009 12:14 AM
Use metal SIPs. Double the amount of fasteners you would use on a stationary structure. Use adhesive on all joints and connections.
Building Designer<br>PANELfusion, LLC, Tampa, FL<br>simon@panelfusion(dot com)<br>"Metal SIP Advocate"
ls7corveteUser is Offline
30 Jul 2010 09:08 PM
Any news on this project? Sounds interesting.
30 Jul 2010 09:14 PM
If 4x8' is OK for an application, are there reasons not to just glue sheet steel to foam instead of buying SIPs? I've never seen a SIP, so I don't know how they are made.
31 Jul 2010 06:03 AM
Posted By jonr on 30 Jul 2010 09:14 PM
sure if you have the right adhesive,  roll coater, press or vacuum bag , you could DIY, but you could not do it for less than you can buy it
Bumping for interest.
People Online People Online: Visitors Visitors: 361 Members Members: 0 Total Total: 361
