"PolyUrethane ICFs" ?
Last Post 06 Sep 2009 11:38 AM by cmkavala. 12 Replies.
ErgoDeskUser is Offline
04 Sep 2009 06:26 PM
Lesson #1 - Why you won't find Polyurethane ICFs on the job site. Answer -
05 Sep 2009 02:05 PM
1. The foaming process creates a "skin" that prevents Concrete from bonding to the foam.
arkie6User is Offline
05 Sep 2009 04:19 PM
Why does the structural concrete need to bond to the foam in an ICF assembled wall?
TorbenUser is Offline
05 Sep 2009 07:35 PM
Then why do EPS foam SIPs use polyurethane adhesive to bond to the skins?
05 Sep 2009 07:53 PM
Hey My WHY? was first.
05 Sep 2009 08:01 PM
Okay your why first... Because EPS is cheaper than polyurethane.
05 Sep 2009 08:04 PM
Yes I agree, also EPS is better at insulating, so Cheaper and Better.
richmUser is Offline
05 Sep 2009 08:39 PM
ergodesk,
can you give facts as to "EPS is better at insulating". I am trying to figure all this stuff out and a factual answer with a source would really help!
richm
05 Sep 2009 08:47 PM
Sure, http://www.epsmolders.org/
05 Sep 2009 08:54 PM
Environmentalists complain that EPS will not break down in land fills, but you never hear that about Polyurethane foam. Why?
05 Sep 2009 09:41 PM
ergodesk,
Just read the info at EPS Molders Assoc. I could not find where it said that EPS is better at insulating. They sure did write alot about the "aged" (or longer - 10 to 15 yrs) R values of polyurethane and iso. Tests have shown it to go down to 5.6/" whereas EPS lost no R value. That is very good to know.
It was also interesting to see their calculations for equal R values per x inches of material at prices that I have no idea as to the accuracy of.
Does anyone know the current price of 1 lb. density EPS, 1.2 lb EPS and polyurethane (NOT iso!!!) per board foot?
I would like to see some data collected since those tests were done in 1992. Do you know of anything in the works? There must be something - that was 17 years ago!
Also, please tell me if this should be a new thread:
Does anyone have experience with the relatively new EPS from BASF - Neopor. I have researched all I can find and it looks to be the next generation of EPS. Higher K factors, perhaps stronger, no info as to price. Is there a manufacturing plant in the US? All info I have found refers to it being from Germany.
Thanks for all the info all you contributors give!
richm
05 Sep 2009 10:17 PM
I would suggest that you contact many of the builders using the NEW BASF EPS Foams.
Posted By arkie6 on 09/05/2009 4:19 PM
Arkie6;
you hit it on the head, it does not need to bond at all as it is not part of the structural component.
It is a thermal element of the wall
People Online People Online: Visitors Visitors: 307 Members Members: 0 Total Total: 307
