30 ft SIP wall height
Last Post 22 Sep 2009 01:01 PM by azbuilder. 18 Replies.
LiviuUser is Offline
19 Sep 2009 06:57 PM
We need to build a warehouse 30 ft high , clear span. It is possible to use three 10 ft panels one over the other? Does the spline needs to be one 30 ft piece? What should we use for spline? can anybody come up with a drawing of the connection details for this case? No load  other than the roof on top of the building.  Thank you!
TorbenUser is Offline
19 Sep 2009 10:02 PM
Have you considered metal skin SIPs?  The widths are only about 3.5' but the lengths go well over 40'.  See photo in this link:
http://www.precisionfoamfabricators.com/sips.asp
19 Sep 2009 10:23 PM
Posted By Liviu on 09/19/2009 6:57 PM
Panels are available up to 53 ft. but to say there is no load?
unless the building is inside of another building you will always wind load, 30 ft. would need to be back braced some how. Depending on what area of the country and the wind loads. it might be able to be done with a 12" x 30 ft. panel.
we use 4" or 6" at 30ft. but they are back braced with steel joist system, no splines
Attachment: Franklin 003.jpg
Attachment: SIP example.JPG
Attachment: 100_1591.jpg
20 Sep 2009 10:41 AM
The only panels we can produce there are 4X10.
20 Sep 2009 11:29 AM
Posted By Liviu on 09/20/2009 10:41 AM
Where is there?
20 Sep 2009 12:06 PM
Iraq.
20 Sep 2009 01:29 PM
then you have an issue, you cannot simply stack 3 - 10 foot sips one on top of the other without an additional frame
 30 foot long splines are not the answer.
There is a serious hinge (buckling) point at each joint
SIPBUILDERUser is Offline
20 Sep 2009 06:34 PM
Use PSL OR LVL enginnered lumber 3.5 x 5.5 lvl and 5.25 x 5.25 psl are avalable most everywere int he country. 4ft wide or 8 ft wide panel by 30 ft tall depending on your enineer's specificaltions. Courtney Cook
21 Sep 2009 06:39 AM
OSB is not readily available in 30ft. lengths , not impossible, I have done jobs with 28ft. osb, but you wil pay dearly to get it.
But just because you can but a panel 30 ft. does not mean it can be used unsupported 30ft.
But this is not a solution for Liviu, as they are trying to make 10ft. tall panels usable for 30 ft. walls, a task not possible without a sub-frame
21 Sep 2009 06:47 AM
Our 10" walls will go unsupported 36ft. @ L/120 or  30ft @ L/180 with a 20# wind load
21 Sep 2009 07:16 PM
Can we do a structure from cold rolled steel? and then put the SIP panels on the outside? I am not sure if the cold rolled steel structure can be built at 30 ft high, i assume it is. Or maybe we can use  steel splines? The problem that our rollformer will come in last .
21 Sep 2009 07:47 PM
Posted By Liviu on 09/21/2009 7:16 PM
You need an engineered red iron sub frame, if you are talking about cold rolled steel stud framing it is not sufficient at 30ft. tall.
Your SIP system already has a designed spline , it would be dificult to substitute some sort of steel spline,
What ever you do, it will need the guidance of an engineer.
at 30 ft.tall andin Iraq, I am only guessing something important will be inside?
its not like building a shed in the back yard and if it falls down, no big deal
ErgoDeskUser is Offline
21 Sep 2009 07:54 PM
Can we do a structure from cold rolled steel? and then put the SIP panels on the outside? I am not sure if the cold rolled steel structure can be built at 30 ft high, i assume it is. Or maybe we can use  steel splines? The problem that our rollformer will come in last .[/quote]
Yes you can. Koreteck has the System you need.
Attachment: Koreteck Wall System.jpg
21 Sep 2009 08:20 PM
All we have available are  SIP's panels, MGO  4X10 max and the rollformer for CFS. So now we want to find out what is the best way to build the shop around those machines. It will be around 60.000 sqft in 3 sections.
21 Sep 2009 09:10 PM
Posted By ergodesk on 09/21/2009 7:54 PM
I don't see any 30ft. walls
21 Sep 2009 09:21 PM
Yes you can. Koreteck has the System you need. StyroHomeNews.blogspot.com
cmkavala, you can cut and past the address below and check-out the specks for your self. Cheers http://www.koreteck.com/ko_system.php
21 Sep 2009 09:26 PM
Steel Sips in reverse eh!
Attachment: installationphoto.jpg
Attachment: ScreenShot2009227.jpg
22 Sep 2009 06:01 AM
Posted By ergodesk on 09/21/2009 9:21 PM
Ergo;
the specks are on my face but I did check out the specs , most any sip is stackable, that is not the issue by Liviu.
They are needing a free standing 30 ft. SIP wall which Koreteck cannot provide.
Our Shadowline panel at 10" thick would stand in one piece at 30ft. @  a 20# wind load.
But Liviu is between a rock and a hard place with 10ft. panels not designed to stack unsupported and a cold rolled machine, they are in dire need of a properly engineered structure.
Even if there is no code requirement they are at great risk erecting a building that could potentially fall down causing injury or loss of life
azbuilderUser is Offline
Posted By cmkavala on 09/22/2009 6:01 AM
Seems like a steel subframe over which any available SIP could be wrapped might be the best combination of speed and cost, especially given the location.
Green building across Northern Arizona - VerdeHome.com
People Online People Online: Visitors Visitors: 313 Members Members: 0 Total Total: 313
