New SIP house in OKC, OK area need bids.
Last Post 14 Oct 2011 02:12 PM by KwikBuild. 10 Replies.
DaveyUser is Offline
21 Sep 2009 08:23 PM
We are planning to build a SIP framed and roofed house here in central Oklahoma.  We would like to communicate with potential SIP experienced contractors in our area.  We have been thinking of erecting the walls ourselves, but the roof is out of the question.
Since we are also DIY'ers, we are looking to just have the house "dried in" once we get the plumbing lined out.  We will need plumbing and electrical contractors too.
Current thinking is osb SIPs, but steel seems to be lighter, thuis easier to handle.
Current status is:  land has been cleared, electric company is in the process of running the service to the building site.  We live on-site.
Dave
21 Sep 2009 09:15 PM
Posted By Davey on 09/21/2009 8:23 PM
Dave
Dave;
you are right steel is 1/2 the weight of OSB panels , no crane needed, would be happy to quote
The SipperUser is Offline
22 Sep 2009 12:57 PM
Davey, If you're considering OSB/EPS SIPs you could contact ACH Foam Technologies (R-Control SIPs) in Denver, Co. They should be able to refer an experienced contractor in your area,
Good luck with your project, whatever system and product that you decide to use
The Sipper
boswell constructionUser is Offline
05 Oct 2009 09:49 PM
davey;9-21   i have been working with sips for over 25 years  i would be happy to discuss your project with you  (barry)  BOSWELL CONSTRUCTION SERVICES  918-869-9891 www.boswell-construction.com
08 Oct 2009 06:25 AM
Dave;
Make sure you get references from builders with specifically SIP experience, you don't want someone learning on your project
08 Oct 2009 02:15 PM
Thanks to all that have responded.
The project is running slow due to the weather. The electric folks are installing new poles to get back to the site, and it has just been too wet for their trucks. Poles are just lying on the ground currently.
Hopefully foundation will begin in 2-3 weeks. We'll see.
Davey
KwikBuildUser is Offline
08 Oct 2009 02:29 PM
Dave,
Check out our web site, www.KwikBuildPanels.com We have had a 70 yr old woman and a 71 yr old man stand a 2,800 sq ft home in 4 days (walls only). You sound much younger, it should be less of a problem for you! Take a look!
11 Oct 2009 02:05 PM
something to consider  weather patterns this time of year are very rainy  you may consider a track style trencher for footings  a portable  generator for interum electrical and a portable pump provider to assist with concrete install i know much of this is relative but if you want or need to get going these are options ,we have had alot of exsp. in delivering jobs with challenging circumstances    BBB
jrquinn57User is Offline
15 Oct 2009 08:29 PM
Davey,
I represent Enercept Building Systems. Tony Leddy is an experienced and talented contractor in OKC with extensive SIP experience. He can be reached at [email protected].
Good luck,
Joe Quinn
(800) 658-3303
PhkowboyUser is Offline
14 Oct 2011 01:24 PM
Davey,
Can you update me on the status of your SIP house?
Patrick
Hi Dave,
Take a look at our site www.kwikbuildpanels.com  We have a panel system that you can install yourself, including the roof.
No heavy equipment required, basically just a screw gun.  Panels weight between 1.5 to 2.5 lbs/sq ft.
Best,
David
Kwik-Build Panels
People Online People Online: Visitors Visitors: 428 Members Members: 0 Total Total: 428
