Mounting Windows on SIPS
Last Post 02 Oct 2009 10:46 AM by tmsu. 1 Replies.
sgo70User is Offline
30 Sep 2009 08:05 PM
I have my walls up now and I'm starting to think of windows. I had my plans engineered with LVL's above my window openings so I didn't have to build them up as I go and I wouldn't have excess wood inside my SIPs. Now when I cut out my window openings I was going to frame the rough opening with 2x6's but my supplier suggested just using magboard. Sounds like a good idea it's just that we have triple pane windows and most are over 6' tall. I'm not convinced that the windows won't start to pull out over time and I figure the 2x6 would give me something to bite into. Any input on this would sure help. Thanks, Sean
tmsuUser is Offline
Sean, While I cannot help you with your question regarding the magboard (I built mine with the "dreaded" OSB), here are few things I missed. *Measure twice, cut once for your openinings. It is pain in the neck once you buck out the window and it is slightly too small. I know stooopid on my part. *If you are using extension jambs, make sure they are long enough. I went with standard extension jambs on my windows. Well "standard" for a 2 x 6 frame is 1/2" smaller than the SIP (at least for mine 6.5"). Anyway, I had to rip and cut 1/2" extensions for my extensions (Clearly I am not a professional, duh!). Turned out fine but a lot of extra work. *Finally, how is the 'echo' or sound travel through the wall? I ask as my SIPs (OSB w/EPS) have a hollow sound and sound travels pretty easily through it. Unfortunately, I didn't see the fixes for this until after I was done (again, duh). Anyway, there are (2) ways I have read about in case you want to know. Some on here advocated furring out a wall inside, thus creating a dead space that will eat up the sound. Another way I have read is using a product called 'Acoustiblock' (sp?). It looks like a roll of thin (1/4") rubber that goes on the inside/outside of the SIP. It is also designed to go in between floor truss/joist and the sub-floor. It is not cheap and I cannot speak to its effectiveness but I would have tried this way had I known about it. Your build looks great. Happy building!
People Online People Online: Visitors Visitors: 217 Members Members: 0 Total Total: 217
