Benefits of SIPs
Last Post 25 Nov 2009 06:56 PM by cmkavala. 46 Replies.
Page 3 of 3 << < 123
25 Nov 2009 04:54 AM
Posted By Torben on 11/24/2009 11:49 PM
You may also want to consider some type of sheathing between a metal SIP roof panel and standing seam metal roof. I've heard that the metal roof clips will telegraph up through the roof. One fix I heard of was using something like 3/4" R-Max sheathing to support the standing seam roof beyond the clip locations. I would think this would also help dampen the sound. I was thinking of using a peel and stick underlayment covered by R-Max sheets (with cutouts for the standing seam clip locations).
Torben:
 the peel n stick is a good idea, but do not cut out for clips , instead use a continious nail strip standing seam.
3/4" R-max is totally unecessary
25 Nov 2009 04:57 AM
Posted By Jelly on 11/24/2009 8:19 PM
JeffD, do you think the self-adhering bituminous underlayment goes farther than just plain roofing felt in absorbing the noise? I've got a 5v crimp roof planned to go directly on to 4 inch metal panels with just 30 lb felt in between, but I can switch gears if it would make a big difference.
the 4" could be problematic on a roof for sound, 6" is far superior
25 Nov 2009 08:14 AM
Posted By cmkavala on 11/25/2009 4:57 AM
Yes, Chris, there are A LOT of things I wish I had done differently. Right about now is where you can say "I told you so."    :)
But what do you think about the 30 lb. felt versus the self-adhering bituminous underlayment? I like JeffD's idea if it will make a big difference. Of course I have to look into price.
The majority of the living space of the house is under a ceiling which is under a conditioned attic. So regarding my 4 inch roof, I don't think sound would really be an issue in those areas.
However there are two 2nd floor bedrooms which are directly underneath the roof with no attic in between. I will definitely fur out the ceiling there, and maybe add some rockwool?
25 Nov 2009 10:57 AM
Jelly;
I like the peel-n-stick better for several reasons, cost is about 40 cents/sq. ft.
you will be OK with the ceiling drops, but definitely needs furred in other areas
25 Nov 2009 06:20 PM
So wouldn't the seam tape and buckets of elastomeric sealant that I bought be redundant if I used peel-n-stick?
25 Nov 2009 06:47 PM
Jelly,
Yes it would be redundant.
Posted By Jelly on 11/25/2009 6:20 PM
 elastomeric serves no purpose, if you seal the joints with tape the metal is already impervious to water, you are looking for sound deadening that the bitumious peel-n-stick will provide
People Online People Online: Visitors Visitors: 172 Members Members: 0 Total Total: 172
