Galvanized steel tube framed SIPS
Last Post 02 Nov 2009 12:42 PM by mark S. 11 Replies.
mark SUser is Offline
28 Oct 2009 12:05 PM
I know of two companies who make these in Ohio.  Are there any other companies that use galvanized tube as the framing for the SIPs?
richmUser is Offline
28 Oct 2009 09:15 PM
Mark,
I would like to see that! Can you give their name or website address?
richm
29 Oct 2009 07:44 AM
I am hoping someone else can give me additional sources.
The two I know are:
Green Source  216-851-4641  1170 Ivanhoe Road Cleveland OH 44110
www.greensourceproducts.com
TechBuilt  440-622-3958 435 W. Prospect, Painesville OH 44077
http://www.techbuilt.com/
Would be interested in others experiences too.
JRinWVUser is Offline
31 Oct 2009 07:33 AM
I saw a really nice strawbale home with a metal frame, but it wasn't galvanized, just painted. Since it's in a dry environment, I'm not sure what the extra money gets you in this case.
31 Oct 2009 11:03 AM
How do those systems handle heat transfer through the metal frame?
31 Oct 2009 01:59 PM
Posted By mark S on 10/29/2009 7:44 AM
The two I know are:
I had heard  that techbuilt's plant was closed
31 Oct 2009 06:26 PM
As for techbilt I just saw a project finished last month. Plan on visiting their plant soon. As for heat transfer the tubes don't touch. Picture two 1x2 x 18 ga tubes (or 2x2) opposite each other with rigid foam in between (5.5" up to 12") They sculpt out where the tubes go- why I don't know because the air space would get you extra R value. The tubes are fastened by screws. And all the strength appear to be from the tubes for the loads.
31 Oct 2009 06:30 PM
Galvanzed versus painted steel. I think the only reason is Leed credits and marketing. Otherwise I also don't see the point- steel buildings are built every day with out being galvanized. It only seems the "carport" type buildings are made with the galvanized tubes.
ErgoDeskUser is Offline
31 Oct 2009 07:13 PM
Posted By mark S on 10/31/2009 6:26 PM
As for techbilt I just saw a project finished last month. Plan on visiting their plant soon. As for heat transfer the tubes don't touch. Picture two 1x2 x 18 ga tubes (or 2x2) opposite each other with rigid foam in between (5.5" up to 12") They sculpt out where the tubes go- why I don't know because the air space would get you extra R value. The tubes are fastened by screws. And all the strength appear to be from the tubes for the loads.[/quote]
Are you talking about VIRTUVIAN http://www.vitruvianbuilt.com/
Attachment: P2200063.jpg
01 Nov 2009 11:23 AM
Yes this is the same system. Just a lighter gauge tube. Where do I find a complete listing of everyone building this way?
01 Nov 2009 01:08 PM
Posted By mark S on 11/01/2009 11:23 AM
http://StyroHomeNews.blogspot.com StyroHomeNews Blog
Your picture of a Dummies book- is that a real book. ANd if so where can I find it.
Thank you
People Online People Online: Visitors Visitors: 185 Members Members: 0 Total Total: 185
