Ventilation for my SIPS home
Last Post 10 Nov 2009 05:41 AM by cmkavala. 11 Replies.
vbUser is Offline
05 Nov 2009 10:17 PM
I don't want to hijack Kenneth's Thread on Moisture problems so I will start a new one. My home design is for 1800 sq feet, SIPS walls SIPS roof, Slab floor, open floor plan. All this means I have no room for duct. How should I ventilate this house?
06 Nov 2009 06:13 AM
Posted By vb on 11/05/2009 10:17 PM
vb,
is this an existing house that you have a problem with or a house under constrction?
what part of country?
vbUser is Offline
06 Nov 2009 08:50 AM
I am having the shop drawings done now, and I will build in the Pacific Northwest. The one contractor that has actually responded to my inquiries (I thought nobody has any work??) told me that an HRV is not appropriate for my application.
pdkUser is Offline
06 Nov 2009 08:55 AM
In any type of tight construction whether it be sip, icf or some other will always need a HRV. You are trapping lots of gases off furniture, carpet, cooking, bathrooms, etc. that have to be vented. When you vent you expel heat as well. Its best to keep as much of the heat and expel the gases and orders. Unless its not cold in your area I would go to an HRV.
06 Nov 2009 01:05 PM
Posted By pdk on 11/06/2009 8:55 AM
you can economically introduce fresh air and positive pressure without an HRV or ERV. In northern climates it is a little more important to use an HRV.
If you are building "Green" you should be looking at the "off gassing" of the product you introduce into the living space. If you don't put it in the house you need not worry about the gases and odors
vbUser is Offline
06 Nov 2009 07:52 PM
Will an HRV work If I can't duct to all rooms ?
TorbenUser is Offline
06 Nov 2009 08:49 PM
If you have a two story house you can duct through open web floor joists. If it is one story you could try to put in some boxed in plenums for the ducts that also provide some architectural detail. The plenums could include uplighting that washes across a cathedral ceiling or inset downlights. The HRV ducts don't have to go to every room but should be planned in a way that tends to ventilate the entire house. For example exhaust bathrooms, laundry and storage areas to outside and provide fresh air to bedrooms and other living areas. The intake and exhaust spaces will naturally equalize providing air flow through the home.
07 Nov 2009 08:24 AM
Posted By vb on 11/06/2009 7:52 PM
Yes an HRV will work, but I have not seen a house yet that cannot be fully ducted with ceiling drops or bulkheads
thevidyUser is Offline
09 Nov 2009 02:37 AM
Vb since it's early on in the design phase I would highly recommend the book by Phd Joseph Lstiburek called "Builder's guide to Structural Insulated Panels" (for all climates) it will be the best $40.00 or so dolllars you will spend on building your sip house. Many on this forum have probably heard of him and know he is one of the industry leaders on building practices and forensics. The book has a good section on different methods of how to ventilate and the reasons why. Even though he is a Phd it is a very easy read and a wealth of info. Remember to build it tight but ventilate it right.
jrquinn57User is Offline
09 Nov 2009 10:37 AM
VB- I agree with many of the posts. Chris is right, if you are still in the design phase, I think that ducting and ventilation should be built into the design. Several contractors I work with box out the ridge(s) to run properly sized round duct work at the ridge to reach all areas of your new home. A HRV is essential in your cool humid climate.
Joe Quinn
Regional Sales Manager
Enercept Building Systems
(800) 658-3303
vbUser is Offline
09 Nov 2009 09:44 PM
Thanks guys I'll get the book, it sounds like good reading but no way am I going to cover my (future) beautiful ridge beam or drop my vaulted ceiling. I'll figure something out.. Hey Joe, I knew a Joe Quinn once. Did you ever live in the PNW?
VB;
no need to cover up ridge beam, you should rely on your designers creativity to disguise the duct runs, such as making a plant shelf that doubles as a main trunk line, drop closets to conceal duct supply lines
People Online People Online: Visitors Visitors: 212 Members Members: 0 Total Total: 212
