Shed style Small Sips Earth Shelter...suggestions
Last Post 01 Dec 2009 01:03 PM by pdk. 8 Replies.
CURTIS596User is Offline
27 Nov 2009 09:03 AM
I want to build a small earth shelter home. I am thinking 20x48. With a shed style roof, this should allow for 6 8x24 foot panels for the roof. Being so simple, what am I looking at for cost? I see a lot of price per square feet but I can assume they have a bit more complicated roof. This is a simple as it gets.
pdkUser is Offline
29 Nov 2009 12:49 PM
where are you located?
29 Nov 2009 12:54 PM
SW Michigan I should clarify, the reason for the 24 foot panels is I would like to span front to back with no interior load bearing walls.
pdkUser is Offline
29 Nov 2009 01:19 PM
Ok, I can get back to you on Monday.  Our company makes sip panels in Grand rapids, Mi. and ships anywhere.  No sip panel will span 24' so you will need a beam at least to carry the load.  If you wish send me a sketch so I can price correctly.  Thickness?8",10,12,?, spines?  foam, osb or 2x material?  We also send the screws, bits, sealant and sip tape.  em:[email protected]
29 Nov 2009 01:26 PM
I guess I was under the impression that it would span 20'...if it won't then I might look at some other options.
29 Nov 2009 01:47 PM
Posted By pdk on 11/29/2009 1:19 PM
Not true.......... we have spanned 24 ft many times with 6" panels, depending on your snow load you may need to go to a 10" or 12" , but definitely can go 24ft.
what is you snow load?
pdkUser is Offline
29 Nov 2009 02:00 PM
Osb sheathed sip panels on their own will not span 24' unless you install lumber in the panels. Right now I'm working on a project on the lake shore which requires 3-14" lvls at 4' oc to span 21' due to the 70# snow load.
29 Nov 2009 04:31 PM
Posted By pdk on 11/29/2009 2:00 PM
I know OSB SIPs will not span that far, however our panels with no additional support  will make the span......  a 12" @ 24ft will support 55# per sq. ft.
pdkUser is Offline
Curtis
Your panels plus tax and delivery would be $7378.34 based on a maximum live and dead load of 84# per sq. ft.  It would include sip tape, screws, panels and sealant.  Splines would be double 2x12s at 48" oc supplied by you.  A panel layout drawing would also be included.
Pdk
People Online People Online: Visitors Visitors: 397 Members Members: 0 Total Total: 397
