Posted By trigem1 on 12/06/2009 5:51 PM
...I’m thinking passive solar with a hot water solar system and a hot water storage tank and in-floor radiant heat with boiler backup would be the most efficient and cost effective, but I’m open to suggestions. What would be the perfect recipe?
Steve,
You are very close. Google Solar Harvest and see what they did. You have the advantage of living in an area(Colorado) with high Solar Insolation. Along with
Solar Harvest I would suggest Super Insulating(R-40 walls), and using active solar and a large storage tank(1000's of gallons).
One idea that I'm toying with is using a direct vent pellet stove not only for temporary space heating but also as way to recharge the storage tank during cold cloudy periods(pump the stored water thru it). And, of course, with all of that hot water, using radiant heat.
Good Luck!
