Posted By pdk on 12/30/2009 7:51 AM
jerkylips
With the preliminary design you posted standard trusses sprayed with foam will work fine and will be very easy to install. As for the difference between sips and sprayed foam performance: You are heating the same space so the only thing that is different would be the conduction through the trusses themselves @24" oc. Keep in mind you would only need raised heel trusses if you were going to blanket or blow in lose insulation. Don't do raised heel trusses with sprayed foam for you would be wasting your money. As I said in a previous post you would be wasting monies with sips with this roof design.
thanks, good to know. I must not understand the concept of raised heel trusses, though - I don't understand why they'd be good for blown in insulation but not needed for sprayed in?
About conduction through the trusses. there are several points where the lumber will be hitting the drywall & also the outer skin of the roof, but it's not like a wall, where they're in contact across the entire length - so that should minimize the thermal bridging, right?
