Posted By Jelly on 22 May 2010 07:29 AM
Looks good! Do I see some "beams" made out of strips of panel and 18 ga. steel, for example where the overhead door track is connected above?
What a great eye! yes because the pitch was so high over the 12 x 14 ft. OH door, the installer needed a lower point to attach the track to, so we dug a 18" x 18 ft. drop out of the scrap pile capped it with 18 ga. steel track and created a panel beam to support the back end of the OH door track.
That was the only place a panel beam was used, the other ridge beam are the standard 6" w x 14" h steel box beams
The smaller 8 x 8 OH door track is attached to the bottom side of the 12" thick SIP floor skin , that floor panel clear spans 21 ft.
