SIP Man Cave
Last Post 29 May 2010 07:32 AM by cmkavala. 6 Replies.
21 May 2010 07:57 PM
this 3600 sq. ft. 40 x 80 x 16 with 400 sq. ft.loft, built for a guy with all the toys ............ started on 5/10 and completed on 5/15 including overhead doors erected with just 4 men ,............... Location: Brunswick, Ga.
http://viewmorepics.myspace.com/ind...Id=1233713
22 May 2010 07:29 AM
Looks good! Do I see some "beams" made out of strips of panel and 18 ga. steel, for example where the overhead door track is connected above?
22 May 2010 08:11 AM
Posted By Jelly on 22 May 2010 07:29 AM
What a great eye! yes because the pitch was so high  over the 12 x 14 ft. OH door, the installer needed a lower point to attach the track to, so we dug a 18" x 18 ft. drop out of the scrap pile capped it with 18 ga. steel track and created a panel beam to support the back end of the OH door track.
That was the only place a panel beam was used, the other ridge beam are the standard 6" w x 14" h steel box beams
The smaller 8 x 8 OH door track is attached to the bottom side of the 12" thick SIP floor skin , that floor panel clear spans 21 ft.
greentreeUser is Offline
22 May 2010 09:33 AM
So whats up with the bottom stair landing clearance into the area underneath the loft? Looks a little tight.
22 May 2010 10:24 AM
Posted By greentree on 22 May 2010 09:33 AM
Good observation, owner supplied stairs and we helped install, cut out in panel partition allows for code compliant landing at bottom and access from shop. I believe he is going to alter stair rail/post on last tread to allow easier access from lower room
Owner also fabricated his own steel frame walk in doors making a 6" throat in jamb to accomodate panel thickness
ls7corveteUser is Offline
28 May 2010 10:20 PM
Any siding? drywall going in?
Posted By ls7corvete on 28 May 2010 10:20 PM
No drywall or siding , panel wall joints are simply caulked, roof joints are are taped with a white "perm-bond" pressure sensitive tape.
On the 7th day the owner locked his truck in building and already had several "Home Depot" type storage racks installed
