Posted By palmtree on 02 Jun 2010 11:59 PM
I have read that one of the reasons sips insulate better than typical stick construction with fiberglass bats is because of the tight envelope. So tight that an air exchanger is necessary. Yet an air exchanger is another up front expense and also another energy consumer -- even as a heat exchanger. As the name implies, heat is being exchanged therefore heat is being lost or gained. So my question is: where is the breaking point where a fresh air exchanger is required and why go beyond it. There must be a point where you can stop sealing up every little crack so the house can still be very well insulated and pretty tight but avoid the upfront and ongoing expense of a fresh air exchanger. I ask this because we go many months out of the year with our windows open or maybe open at night and closed in the daytime during spring and the opposite in the fall. Any ideas or comments? Thanks, Brett
we put one in our house. we actually haven't moved in yet (3 weeks!!!!!) so I don't have any real world experience, but I can tell you my thought process. we're going to be in the house a long time. air quality is probably the #1 concern. If your house is full of stale air, I don't know that you realize it, because it's gradual - but I think it does take its toll on your health. As mentioned before, I think where you live is a factor too. I live in WI, so we have the windows closed & possibly furnace on from october through march, for sure, and then probably have a solid month of windows closed & ac on - that's 7 months of the year. So there's your health, and also the health of the house. Not that it's automatically going to happen, but I think you run more of a risk of moisture & mold building up in the home if you don't have good ventilation. I think the total cost of ours was about $2000. Not insignificant, but if you look at it in terms of a mortgage payment, it's probably an extra $10/month.
