SIP panel sliding door.
Last Post 22 Jun 2010 07:17 AM by ICFconstruction. 15 Replies.
17 Jun 2010 09:03 PM
I want to use sip panels with 4-6 inches of EPS to make sliding doors, instead of and in addition to over-head doors. The building department wants drawings to submit with the permit application. My door sizes are 10x12 and 10x10. The sliding door between the house and garage need to have a 20 minute fire rating.
Does anyone know of drawings that might satisfy them?
Do any sips have a fire rating?
17 Jun 2010 09:27 PM
Brad;
mineral wool core panels have a 1 hour rating and some urethane have a 1 hour rating, I don't know of any EPS cores that have a rating without the addition of drywall
TorbenUser is Offline
18 Jun 2010 01:26 PM
Kingspan has a fire rated panel
http://www.kingspanpanels.us/Industrial/ThermalspanWall/KS42MF.aspx
19 Jun 2010 04:52 PM
R309.1 Opening protection. Openings from a private garage
directly into a room used for sleeping purposes shall not be per-
mitted. Other openings between the garage and residence shall
be equipped with solid wood doors not less than 13/8 inches (35
mm) in thickness, solid or honeycomb core steel doors not less
than 13/8 inches (35 mm) thick, or 20-minute fire-rated doors.
In my opinion any steel skinned SIP would meet the intent of this IBC (International Building Code) code passage, especially a urethane cored Metal SIP.
20 Jun 2010 10:29 AM
Thanks for the input, steel sips would be ideal. Any drawings? Even sip cross sections?
20 Jun 2010 11:41 AM
Posted By ICFconstruction on 20 Jun 2010 10:29 AM
20 Jun 2010 12:14 PM
Thank you, if I add that to a steel sip cross section I should be good.
20 Jun 2010 01:59 PM
Do you think I can put a person door in a sliding door made of a sip panels?
20 Jun 2010 03:38 PM
Brad;
it could be done with a metal frame, I would use a piano hinge to hang it
20 Jun 2010 05:53 PM
Brad,
Check with commerical door mfgrs such as Plyco.
They should have an all metal door unit that would work for you.
20 Jun 2010 09:11 PM
Why use a piano hinge?
20 Jun 2010 09:17 PM
Posted By ICFconstruction on 20 Jun 2010 09:11 PM
Low profile and  durable
greentreeUser is Offline
21 Jun 2010 10:57 PM
Our fire doors here usually need to be self closing, how would you pull that off with sliding doors?
22 Jun 2010 06:20 AM
mount closer on outside
22 Jun 2010 06:24 AM
Posted By greentree on 21 Jun 2010 10:57 PM
the thread started as a "20 min." door,  that is not a fire door, nor is a closer required for a 20 min. door
No self closer is required.
