torben;
metwood works particularly well with sips, the one below is a 14" x 35ft beam carrying a roof that is 40ft. depth. made in Va. and readily available. Beams use Dietrich components welded together andinternally reinforced with welded rebar.
For shorter spans you can simply create box beams by using "C" stud with track top & bottom
